HG612 Stats
- HG612 Stats
HG612 Stats
09-05-2014 2:10 PM
Hello,
So got my HG612 today and recorded some stats, those in the know (will sit down to learn this stuff at some point!) can you take a looksie see if the stats look okay for 80/20.
DSLAM/MSAN type: BDCM:0xa415 / v0xa415
Modem/router firmware: AnnexA version - A2pv6C030b.d22g
DSL mode: VDSL2
Status: Showtime
Uptime: 40 min 45 sec
Resyncs: 0 (since 09 May 2014 13:56:12)
Downstream Upstream
Attenuation (dB):
Connection speed (kbps): 79999 19999
SNR margin (dB): 14.6 23.2
Power (dBm): 12.4 0.7
Interleave depth: 1 1
INP: 0 0
RSCorr/RS (%): N/A 0.0000
RSUnCorr/RS (%): N/A 0.0000
ES/hour: 13.9 0
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 40311 Kbps, Downstream rate = 111180 Kbps
Path: 0, Upstream rate = 19999 Kbps, Downstream rate = 79999 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 14.6 23.2
Attn(dB): 0.0 0.0
Pwr(dBm): 12.4 0.7
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 23 42
R: 0 16
S: 0.0955 0.3781
L: 20107 5374
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 1478572 616165
OHFErr: 6 0
RS: 0 97690
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 2 0
OCD: 0 0
LCD: 0 0
Total Cells: 375979311 0
Data Cells: 4909279 0
Drop Cells: 0
Bit Errors: 0 0
ES: 5 0
SES: 0 0
UAS: 21 21
AS: 2447
Path 0
INP: 0.00 0.00
PER: 1.64 3.97
delay: 0.00 0.00
OR: 116.56 64.47
Bitswap: 0 0
Total time = 41 min 9 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
Latest 15 minutes time = 11 min 9 sec
FEC: 0 0
CRC: 4 0
ES: 3 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 41 min 9 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Since Link time = 40 min 45 sec
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Thanks Much
Sam
DSL mode: VDSL2
Status: Showtime
Downstream Upstream
Attenuation (dB):
INP: 0 0
ES/hour: 13.9 0
Status: Showtime
Retrain Reason: 0
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 14.6 23.2
Attn(dB): 0.0 0.0
Pwr(dBm): 12.4 0.7
VDSL2 framing
Path 0
B: 239 237
M: 1 1
T: 23 42
R: 0 16
S: 0.0955 0.3781
L: 20107 5374
D: 1 1
I: 240 127
N: 240 254
Counters
Path 0
OHF: 1478572 616165
OHFErr: 6 0
RS: 0 97690
RSCorr: 0 0
RSUnCorr: 0 0
Path 0
HEC: 2 0
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 5 0
SES: 0 0
UAS: 21 21
AS: 2447
Path 0
INP: 0.00 0.00
PER: 1.64 3.97
delay: 0.00 0.00
OR: 116.56 64.47
Bitswap: 0 0
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 4 0
ES: 3 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 21 21
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
FEC: 0 0
CRC: 6 0
ES: 5 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Thanks Much
Sam
Message 1 of 2
(596 Views)
1 REPLY 1
Re: HG612 Stats
09-05-2014 2:53 PM
Message 2 of 2
(313 Views)
