HELP please
- HELP please
HELP please
16-10-2007 4:28 PM
I just had to re-format my PC and now my router won't let me log on to it's page, I tried the default password/username nothing, tried the one I was using prior to reformat and it still won't work...
I am using the NETGEAR DG834PN router..
As you can see accessing the internet isn't a problem though.
Thanks if anyone can help.
Jules x
Jules x
Message 1 of 5
(1,305 Views)
4 REPLIES 4
Re: HELP please
16-10-2007 4:32 PM
Hi
The router password and so on is stored on the router itself, so reformatting your hard drive wouldn't change it.
Message 2 of 5
(445 Views)
Re: HELP please
16-10-2007 4:33 PM
Quote I tried the default password/username
- Sounds like you are getting the right IP as you wouldn't be prompted for the username/password otherwise. As you can't get on with the details you thought it needed, I believe the default un/pw on a netgear is admin/password, no luck getting in with these details either?
Message 3 of 5
(445 Views)
Re: HELP please
16-10-2007 4:44 PM
I think I made it work through my extraordinary powers of telekonesisis.
Message 4 of 5
(445 Views)
Re: HELP please
16-10-2007 4:46 PM
Thanks for replying, and a big thanks to James for ringing, and I now feel really silly as it worked when I was on the phone..sod's law I guess.lol
So thanks again James your a star x
lol @ james...quite possibly
Message 5 of 5
(445 Views)
