HELP WIFI issues
- HELP WIFI issues
HELP WIFI issues
01-06-2019 11:35 AM
Hi weve just moved into a 3 storey town house, can anybody help with the wifi it doesnt work in the room its in or when it does is really slow? Any help will be appreciated
Message 1 of 2
(338 Views)
1 REPLY 1
Re: HELP WIFI issues
02-06-2019 9:35 AM
Hi @vickiedonaldson,
I'm sorry that you're experiencing problems with your connection at your new property and for any inconvenience that this is causing you.
I can see that you have called in since making this post and that an engineer visit has been booked so that this can be investigated further. Our faults team will contact you once we receive an update from our suppliers after the visit but please feel free to get back in touch on here if there's anything else that you'd like to discuss in the meantime.
Message 2 of 2
(287 Views)
