HELP: Internet speed has dropped dramatically.
Azagoth
Usually getting ~10,000 Kbps down and ~1000Kbps up, I turn the computer on this morning and everything is slow as hell.  Check the router and it's reporting this.
6EQObf6
The connection has been rock solid for ages but this has happened overnight, as it was fine when I went to bed at about 03:00 yet at 10:00 this morning it's dropped to unusable levels.   Have tried to disconnecting the connection via the router and rebooting it, still comes back with the same IP address and the same slow speeds.  The phone line is quiet with no noise.  I don't have a test socket, so can't test that.
2 REPLIES 2
Azagoth
Re: HELP: Internet speed has dropped dramatically.
And now the connection has started to constantly drop and reconnect.
tinytaco
Fixes: 29
Hi there @Azagoth Smiley I understand that since these posts, you've had a an update on your fault. Please get back in touch when your phone fault is fixed if the broadband issues continue.
 Noor
