HEC Errors upon re-sync
- HEC Errors upon re-sync
28-06-2010 10:57 PM
The data here shows that in the 12 seconds since syncing and I have already had 32,589 errors. Doesn't that seem high. I use my connection purely for gaming so slightly concerned that my upstream connection might be suffering from something.
Router data
DSL Connection
Link Information
Uptime: 0 days, 0:00:12
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 872 / 8,602
Output Power (Up/Down) [dBm]: 12.0 / 20.5
Line Attenuation (Up/Down) [dB]: 18.5 / 34.0
SN Margin (Up/Down) [dB]: 6.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 32,589 / 0
What could be the problem?
Re: HEC Errors upon re-sync
29-06-2010 12:56 PM
Jojo
29-06-2010 1:10 PM
My pings aren't currently any good either usually I have a ping of about 14m/s. Could you check to see if I have lost my fastpath flag ?
C:\Documents and Settings\HP_Owner>ping www.bbc.co.uk
Pinging www.bbc.net.UK [212.58.246.158] with 32 bytes of data:
Reply from 212.58.246.158: bytes=32 time=80ms TTL=55
Reply from 212.58.246.158: bytes=32 time=66ms TTL=55
Reply from 212.58.246.158: bytes=32 time=61ms TTL=55
Reply from 212.58.246.158: bytes=32 time=87ms TTL=55
Ping statistics for 212.58.246.158:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 61ms, Maximum = 87ms, Average = 73ms
C:\Documents and Settings\HP_Owner>tracert www.bbc.co.uk
Tracing route to www.bbc.net.UK [212.58.246.158]
over a maximum of 30 hops:
1 57 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 87 ms 86 ms 91 ms lo0-central1.pcl-ag04.plus.net [195.166.128.241]
3 88 ms 88 ms 87 ms gi1-10-411.pcl-gw01.plus.net [84.92.6.224]
4 91 ms 92 ms 95 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 99 ms 101 ms 96 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 83 ms 82 ms 87 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 84 ms 86 ms 79 ms 212.58.238.133
8 97 ms 97 ms 102 ms te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
9 97 ms 99 ms 91 ms 212.58.255.12
10 79 ms 74 ms 73 ms fmt-vip01.cwwtf.bbc.co.uk [212.58.246.158]
Trace complete.
29-06-2010 1:43 PM
If you try reconnecting to a different gateway, making sure you have no data transferring at the time and run it again, that would be useful.
As for your interleaving, it is not currently on but the status is set to auto so this means that it can be applied if necessary.
Jojo
29-06-2010 1:47 PM
To connect to a different gateway do I just re-boot by powering down the router or is there another way?
29-06-2010 1:51 PM
Jojo
29-06-2010 2:11 PM
Still showing 33,034 HEC errors with noting else connected to the router whilst syncing.
Link Information
Uptime: 0 days, 0:01:58
Bandwidth (Up/Down) [kbps/kbps]: 880 / 8,335
SN Margin (Up/Down) [dB]: 6.0 / 10.0
FEC Errors (Up/Down): 1 / 0
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 33,034 / 1
Ping and tracert still not good.
Pinging www.bbc.net.uk [212.58.246.161] with 32 bytes of data:
Reply from 212.58.246.161: bytes=32 time=116ms TTL=56
Reply from 212.58.246.161: bytes=32 time=93ms TTL=56
Reply from 212.58.246.161: bytes=32 time=87ms TTL=56
Reply from 212.58.246.161: bytes=32 time=86ms TTL=56
Ping statistics for 212.58.246.161:
Minimum = 86ms, Maximum = 116ms, Average = 95ms
Tracing route to www.bbc.net.uk [212.58.246.161]
1 6 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 80 ms 82 ms 80 ms lo0-central2.thn-ag2.plus.net [195.166.128.230]
3 76 ms 75 ms 82 ms gi1-14-221.thn-gw1.plus.net [84.92.6.200]
4 102 ms 102 ms 99 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 103 ms 108 ms 111 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 113 ms 111 ms 112 ms 212.58.238.133
7 107 ms 102 ms 115 ms te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
8 113 ms 117 ms 119 ms 212.58.255.12
9 122 ms 110 ms 107 ms fmt-vip04.cwwtf.bbc.co.uk [212.58.246.161]
Trace complete.
You mention that interleaving is on auto but I had an order on my account to stay on fastpath so shouldn't this be set to off?
29-06-2010 3:17 PM
This needs to be looked at further so I suggest raising a fault through http://faults.plus.net including the stats you have given here and we will check it further. It is important that you make sure that you are not running anything in the background, it may be useful to use a bandwidth monitor to check this before you raise the fault.
As for the interleaving it is off at the moment, the auto is just keeping the option open to put it on if need be. Have you ever used interleaving before, if so how was it? It may turn out you get better performance with it on. It's easy enough for us to turn it off again if you wanted to try it.
Jojo
29-06-2010 3:30 PM
29-06-2010 3:38 PM
Jojo
29-06-2010 3:41 PM
29-06-2010 4:27 PM
http://www.thinkbroadband.com/tbbmeter.html
you can download think broadband's monitor. I doubt you'll have much trouble using it, as although you say you are not a techie, you do seem to know a thing or two!
Jojo
29-06-2010 4:36 PM
29-06-2010 4:47 PM
Jojo
29-06-2010 5:01 PM
I also quickly upgraded the Thomson software to the latest version 8.2.65 and that has made no difference either.
Pinging www.bbc.net.uk [212.58.246.159] with 32 bytes of data:
Reply from 212.58.246.159: bytes=32 time=116ms TTL=55
Reply from 212.58.246.159: bytes=32 time=113ms TTL=55
Reply from 212.58.246.159: bytes=32 time=138ms TTL=55
Reply from 212.58.246.159: bytes=32 time=137ms TTL=55
Ping statistics for 212.58.246.159:
Minimum = 113ms, Maximum = 138ms, Average = 126ms
Tracing route to www.bbc.net.uk [212.58.246.159]
1 36 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 135 ms 124 ms 118 ms lo0-central2.pcl-ag04.plus.net [195.166.128.242]
3 125 ms 121 ms 127 ms gi1-12-421.pcl-gw01.plus.net [84.92.6.232]
4 125 ms 127 ms 134 ms te2-1.pcl-gw02.plus.net [212.159.1.114]
5 149 ms 218 ms 212 ms te2-2.thn-gw2.plus.net [212.159.0.190]
6 139 ms 134 ms 124 ms rt0.thdo.bbc.co.uk [212.58.239.25]
7 133 ms 122 ms 117 ms 212.58.238.133
8 122 ms 111 ms 107 ms te12-1.hsw0.cwwtf.bbc.co.uk [212.58.239.222]
9 118 ms 107 ms 112 ms 212.58.255.12
10 122 ms 115 ms 121 ms fmt-vip02.cwwtf.bbc.co.uk [212.58.246.159]
Trace complete.
I noticed last night that my usual BT profile (through the BT Speedtester) had jumped up from 7150kbps to 10000kbps last night but as of this morning it had fallen to 7000kbps. Could they have been messing around on my line?
