Google.ch
- Re: Google.ch
Google.ch
30-03-2014 10:33 AM
Is anyone else finding that Google Searches seem to pick google.ch rather than google.co.uk or google.com?
I can fix it by setting my cookies once I've gone to google.co.uk but its a bit annoying,
Edited to add: This is happening across multiple browsers and across operating systems so its something generic.
Message 1 of 7
(1,117 Views)
6 REPLIES 6
Re: Google.ch
30-03-2014 10:38 AM
Sounds like Google is picking up your IP address as one belonging to a different country - happens quite a lot.
Message 2 of 7
(504 Views)
Re: Google.ch
31-03-2014 7:00 AM
But is everyone else noticing it?
And why should google suddenly decide my IP, which either shows up as London or Sheffield (depending on which resource you use), is in Switzerland?
Message 3 of 7
(504 Views)
Re: Google.ch
31-03-2014 7:54 AM
I've not noticed it at all. Are you on a Static IP or dynamic IP ?
It could be that PN have recently bought in a range of IP addresses which were previously assigned to a different country.
Message 4 of 7
(504 Views)
Re: Google.ch
31-03-2014 7:55 AM
Not getting it on 212.159.71.x, so yeah probably your IP address is being seen as from a different country
FTTP 500 regrade from Tues 28th November
Message 5 of 7
(504 Views)
Re: Google.ch
31-03-2014 7:23 PM
Quote from: DomS I've not noticed it at all. Are you on a Static IP or dynamic IP ?
Been on the same static IP for years and years.......
Message 6 of 7
(504 Views)
Re: Google.ch
31-03-2014 8:37 PM
There is a link on this page which you can use to ask them to correct it
https://support.google.com/websearch/answer/873?hl=en
Message 7 of 7
(504 Views)
