Good replacement fibre router?
warpspider
Can anyone suggest a very good replacement Fibre router?
Back when I used adsl I had and was very satisfied with my netgear dg814, I'm kinda at a loss in the fibre market though.  The router that came with my package is very bare bones on features and the wifi is pretty poor.
Re: Good replacement fibre router?
I'm surprised you've not been swamped by recommendations from ASUS users on here (yet?).
RT-N66U and similar seems to please those that use them.
There are so many good routers around, it depends a lot on the features you want (and the price you want to pay).  I use a Fritz!Box 7390 which is expensive but has a fairly unique feature list: http://www.thinkbroadband.com/hardware/reviews/73-fritzbox-7390.html
Call me 'w23'
Fixes: 86
I've a Technicolor 589vn that works pretty well.
PeeGee
Without knowing your requirements, the TP-Link devices provide a low cost (if not feature rich) solution. Though not on fibre, I use a TL-WR1043ND that provides gigbit ethernet and a good 11n300 capability, even though my neighbours router automatically selects the same channel(s) as the best solution Shocked There are models with IPv6 capability and/or dual band.
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
james26
Quote from: Bob
Yes but Plus Net don't give that one for free out do you now? good service let down by shocking bad router if you want w-fi! in the end i bought a apple airport extreme which works really well.
james.
warpspider
Thanks all, gonna check out the Asus I think!
I mainly wanted to be able to set my own mtu, easily setup port forwarding and have better wifi coverage.
