Good replacement fibre router?
- Re: Good replacement fibre router?
29-12-2013 9:07 PM
Can anyone suggest a very good replacement Fibre router?
Back when I used adsl I had and was very satisfied with my netgear dg814, I'm kinda at a loss in the fibre market though. The router that came with my package is very bare bones on features and the wifi is pretty poor.
Message 1 of 6
(1,812 Views)
5 REPLIES 5
29-12-2013 9:52 PM
I'm surprised you've not been swamped by recommendations from ASUS users on here (yet?).
RT-N66U and similar seems to please those that use them.
There are so many good routers around, it depends a lot on the features you want (and the price you want to pay). I use a Fritz!Box 7390 which is expensive but has a fairly unique feature list: http://www.thinkbroadband.com/hardware/reviews/73-fritzbox-7390.html
Call me 'w23'
Message 2 of 6
(571 Views)
29-12-2013 10:30 PM
I've a Technicolor 589vn that works pretty well.
Message 3 of 6
(571 Views)
30-12-2013 10:32 AM
Without knowing your requirements, the TP-Link devices provide a low cost (if not feature rich) solution. Though not on fibre, I use a TL-WR1043ND that provides gigbit ethernet and a good 11n300 capability, even though my neighbours router automatically selects the same channel(s) as the best solution There are models with IPv6 capability and/or dual band.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 4 of 6
(571 Views)
30-12-2013 3:52 PM
Quote from: Bob I've a Technicolor 589vn that works pretty well.
Yes but Plus Net don't give that one for free out do you now? good service let down by shocking bad router if you want w-fi! in the end i bought a apple airport extreme which works really well.
james.
Message 5 of 6
(571 Views)
30-12-2013 8:37 PM
Thanks all, gonna check out the Asus I think!
I mainly wanted to be able to set my own mtu, easily setup port forwarding and have better wifi coverage.
Message 6 of 6
(571 Views)
