Gigabit router to replace Technicolour TG582n
kkar
I am building a new home NAS and I realised that the switch on the technicolour is only 100MB - I assume the only way to get around this is to replace it with a better router - does anyone have any recommendations? gigabit wifi would be nice too but I am mostly concerned about the switch part I guess. Thanks
GeordieMark
Re: Gigabit router to replace Technicolour TG582n
Hi kkar,
I don't believe gigabit wifi is a thing (not in residential routers anyway) but I use a TP-LINK WDR4900 which has gigabit ports and I believe the headline wifi speeds are 950mbps, depending on your other hardware of course, but I've had no issues with throughput on this router wired or wireless.
xreyuk
Gigabit WiFi is a thing, it's called the 802.11ac standard, but not many devices (or even routers) have it yet.
I'd recommend the TP-Link WDR3600 (it's what I have) it has simultaneous 2.4Gz and 5Ghz WiFI banding, or if your hardware supports it, it can combine the two channels to give faster speeds. It's a very customisable router, and comes in around the £50 mark.
pwatson
If the router is otherwise working for you, you could always just buy a gigabit switch?
An example http://www.ebuyer.com/411321-netgear-gs205-5-port-gigabit-ethernet-switch-gs205-100uks
kkar
Thanks Mark_ and Xreyuk. I will check those out. Would they need special settings to get going once they are plugged in to the BT modem?
Also pwatson - can I just plugin that switch to the BT modem or would it need setting? I assume it would be pointless to connect it to the technicolour as the output from that is 100mbit.
Fixes: 12
both those TP-Link routers are for Fibre/Cable, the OP might be ADSL.
pwatson
Quote from: kkar
It's an extra box - Leave you router plugged into the modem and plug a LAN port of the router into the switch.  Connect your devices to the switch instead of the router.
dragon2611
Assuming you don't have any advanced setup where the devices are on different LAN's then you will find anything gigabit capable connected to the switch should be able to benefit from the higher speeds.
Traffic between the 2 devices on the switch shouldn't need to go via the router.
kkar
Quote from: pwatson
Quote from: kkar
The LAN port? can you please tell me what one that is? here is the picture: http://community.plus.net/library/hardware/tg582n-information-and-specifications/
The yellow ports are all 100mbit no? so how would the switch take advantage of this?!
pwatson
Plug one of the yellow ports into the switch.  Any devices plugged into the switch will be able to communicate at 1000Mb/s but wireless devices will be limited to 100Mb/s,  Your broadband is <100Mb/s so there's no problem there.
