Gigabit Router Recomendation
- Gigabit Router Recomendation
05-11-2010 7:03 AM
I want to upgrade the Thompson router supplied with my plusnet account. It works OK'ish for net but is a bottleneck on my home network. Have Cat6e cabling installed and a lynksys gigabit hub, can anyone recomend an alternative that has a good track record with plusnet?
Ps live in rural west cumbria so don't expect any great improvement in net line speeds :(.
Trevor
Trevor
Message 1 of 2
(837 Views)
1 REPLY 1
Re: Gigabit Router Recomendation
07-11-2010 9:39 PM
If you got the money draytek offer them the 2820 range adsl routers only have 1 gigabit port but the 2930 range have 4 gigabit ports but cost over £200
I got the draytel 2710n no gigabit switch but it does wireless n at up to 300 instead of my speedtouchs 54
I tried a billon 7800N its got 4 gigabit but i had to send mine back, every time i wanted to watch my cat via ipcamera using viewnetcam it kept coming up with the router login and password instead of viewnetcam login
why not get the draytel with 2 voip ports and get free** voip calls via plusnet voip (not skype)
Puddy
**= depending on which adsl contract you have
Puddy
Message 2 of 2
(352 Views)
