Getting worse
- Getting worse
- « Previous
- Next »
Re: Getting worse
10-03-2013 9:17 PM
Which router are you using? TG582N?
Message 31 of 34
(240 Views)
Re: Getting worse
10-03-2013 9:20 PM
The latest one Plus Net supply.
I have found out why the Broadband light flash no and didnt before it the Ping tracker graph as i turned it off and it stopped flashing and i turned it back on and start flashing as it send packets to it doesnt it to do that graph
Message 32 of 34
(240 Views)
Re: Getting worse
10-03-2013 9:36 PM
The TBB graphs constantly send pings (every sec or so) to check your line, hence the activity.
How are the speed tests (I believe Sun nights are the busiest periods of the week normally)? Did you try the wifi survey tool?
Message 33 of 34
(240 Views)
Re: Getting worse
10-03-2013 9:44 PM
Been trying the survey trying figure how use it properly
Message 34 of 34
(240 Views)
- « Previous
- Next »
