Getting very fed up with connection issues. (constant disconnections)
SEPL
I have experiencing constant disconnections on my broadband connection. As I type this, I have noticed that my connection is actually down again but I am hoping that it will come back again by the time I have finished...
I have already logged in a ticket for this but I accidently closed it. So when I tried to start a new ticket I have noticed that there is some fault due to maintenance from plusnets side and so I will have to wait into Sunday night/ Monday to relog the fault.
Anyway, it all started about a week ago. I have for the past 7 days been experiencing constant disconnections. Today has been particularly bad, clocking around 1 disconnection every 15 minutes. I am really fed up with this situation as I had the problem about 2 months ago but it just suddenly went away.
So far I have changed 3 routers, all cables, used a different power socket, but disconnections still occur. Before the disconnections started I had changed absolutely no hardware in the flat whatsoever. It just seems very random. Please help me... Sad
19 REPLIES 19
cbcadmin
Re: Getting very fed up with connection issues. (constant disconnections)
Quote from: SEPL
You mention flat. I wonder if neighbours have been on holiday? Wink
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
SEPL
To give you an understanding of just how bad it is, I finished typing the above about 10 minutes ago. I then checked Keeefs' reply and got another disconnection about 2 minutes ago. So far 2 disconnections within 10 minutes. This is absolutely ridiculous.
cbcadmin
Quote from: SEPL
Do you have a long telephone cable run?
Does the telephone cable run near any electronics?
SEPL
Hello and thanks for replying,
Just recovered from yet another disconnection...
No, the telephone is not even connected. It is just the router connected to one of those filter sockets seperating the DSL and phone line. Router is literally next to the dsl socket.
Also, that is the only phone socket that is operational within the whole flat and has been totally fine for about 2-3 years now with Plusnet. No other devices are connected to any other phone socket either.
PS: Got another disc. that's 4 within half an hour.......
dick:quote
SEPL
And here is the info from the router:
Line state Connected
Connection time 0 days, 0:02:41
Downstream 14,374 Kbps
Upstream 888 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 6.3 dB / 14.5 dB
Line attenuation (Down/Up) 28.0 dB / 15.2 dB
Output power (Down/Up) 0.0 dBm / 12.3 dBm
BT test speed: Download: 6.78Mbps Upload:0.74Mbps
cbcadmin
Quote from: SEPL
Quote from: SEPL
So which is it?
SEPL
Well I ve been with plusnet for 2-3 years and was fine. Then 2 months ago the disconnections started but went away after 1 week only to come back again last Sunday....
dick:quote
adamwalker
Fixes: 221
The issue definitely seems to have begun on the 12th, did anything change to your knowledge on that day?
I can see you've logged a fault about this which was the right thing to do, just to answer the question you raised on there the speeds will have decreased due to DLM (dynamic line management) reducing the speed by changing the IP profile, that is a direct result of the connection problem and is designed to increase the speeds again after the dropping connection issue has been fixed.
Our faults team should be getting back to you with more info ASAP:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13533191474369.png" />
 Adam Walker
SEPL
OK that's good news Adam thank you.
Just letting you that the speed is still painfully slow (~0.25Mbps download). Looking forward to have some solution to my problem as it causing me issues with work ...
chrispurvey
I've just made a few adjustments to your account, can you see how your speeds are performing now and let me know.
Chris
DaiaBu
Hi, thought I'd reply to this thread rather than starting a new one.
I've been having exactly the same problems as the opening poster starting about 2 weeks ago. One evening, my router (Netgear DG834) disconnected about 4 times in one hour. Terribly unreliable. The next day it didnt seem as bad, and since then seemed to have settled down a bit.
Last night when I got home from work about 7, the router was disconnected. I restarted it, it took ages to secure a link, then disconnected again. I tried this several times, sometimes managing to connect for only a few minutes at a time (at most) before the connection dropped again.
Losing my rag somewhat, I disconnected the Netgear thinking it may be at fault (although having never had trouble with it before) and plugged in the Thomson supplied by Plusnet. Exactly the same trouble - first off, it wouldn't connect. I powered it off and back on and it connected for a few minutes only, then disconnected while I was browsing; this carried on for most of the evening, maintaining a connection for only a few minutes at a time whilst browsing.
I should add, I was sitting next to the router plugged into the Ethernet port at this time, so the wireless is not at fault.  I was getting nowhere so I turned off the laptop and gave up.
Later in the evening the problem seemed to go away - at half nine or so I was watching Netflix on my phone over the wireless connection and it seemed fine. This morning before work, I turned on my PC just to email one file and it worked fine. But I fear that tonight the problem might have returned.
I've had similar trouble a couple of months back, where for a few nights, the service was terrible unreliable, then it would revert to being fine for a few weeks. however, last night was the worst I have seen it, and it's very frustrating. I thought this might be a problem peculiar to my exchange but seeing a couple of threads like this, is this a wider issue?
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: DaiaBu
Yes and no.  Disconnections are down to some sort of fault on the line or equipment between your house and the telephone exchange.  Such faults are quite common and there are some frequent causes but it's not a wider issue in the sense that it is related to Plusnet.  With problems beyond your exchange you would experience slow or stalled internet whilst the actual connection remained up.
chrispurvey
@DaiaBu
I've posted a log of your connections, there no pattern to your disconnections and in general your line appears very stable.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13534919097376.png" />
I'm going to suggest raising a fault at http://faults.plus.net and completing the diagnostic questions so we can investigate this further if needed.
SEPL
Hello,
Just posting to let you know that the connection seems very stable now. Also I am getting almost twice as much download speed as I used to, which is great.
What exactly was the problem?
Thank you very much for your help!
