Getting tired of these speeds now - could somebody please look into this?
- Getting tired of these speeds now - could somebody...
10-12-2009 4:57 PM
Thats my latest test at 16.55
These are my router stats
Link Information
Uptime: 7 days, 17:45:33
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4,544
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 1.00
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 22.5 / 42.0
SN Margin (Up/Down) [dB]: 20.0 / 13.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 143 / 353,244
CRC Errors (Up/Down): 143 / 3,194
HEC Errors (Up/Down): 84 / 2,779
This has been going on for weeks now - I`m on a plusnet pro product that is supposed to give me good speeds at all times.
What is going on????
Re: Getting tired of these speeds now - could somebody please look into this?
10-12-2009 5:25 PM
... and followed all the recommendations regarding using the master socket etc.
Theo
10-12-2009 9:23 PM
10-12-2009 10:28 PM
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
498 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 498 Kbps
Additional Information:
Your DSL Connection Rate :4544 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
10-12-2009 10:38 PM
Im getting awful speeds in the evening, and about half line speed at off peak. Its been a sudden change that happened about 3 or 4 days ago, no definite answer as to what it is though.
10-12-2009 10:41 PM
10-12-2009 10:54 PM
Im supposed to have no slowdowns either on PAYG but about three days ago I started getting about 500kbps peak and 3mb off peak - usual speed is/was 6-6.5mb.
10-12-2009 11:02 PM
10-12-2009 11:32 PM
11-12-2009 5:46 PM
This is getting beyond a joke now - there seem to be a load of people on here with exactly the same speed problems - surely we havent all suddenly developed a fault?!
11-12-2009 5:54 PM
getting slower
11-12-2009 6:15 PM
With throughput speeds that low on the BT speedtester, you're definitely below the FTR. If your PN Profile appears correct, then there is either a fault, or your exchange backhaul is congested.
B.
11-12-2009 7:56 PM
I used to get 4.5 to 5mbps up until 3 days ago, my support ticket hasn't even been answered
Seriously PlusNet what is going on?
I've had seamless service for the whole 12 months I've been with you but can't go more than another day or so at this speeds.
I can't even do the BT Speedtester as it times out during it
11-12-2009 8:00 PM
@clarkec321, does changing gateways make any difference?
11-12-2009 8:09 PM
Quote from: Mand @Footys, please complete the fault checker (I see you've started it).
Sorry, where do I do that
*edit*
Sorry, don't answer that I'm googling it and if I don't get anywhere I'll post back
