Getting really slow speeds 0.2 to like 1 Mbps
Tom1994
Hi just wondering if anyone can help me, been getting rediculously slow speeds not sure what to do as I'm not great with this sort of stuff thankyou
4 REPLIES 4
Fixes: 334
Re: Getting really slow speeds 0.2 to like 1 Mbps
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
Tom1994
I don't have a phone that can be connected to the phone line is there any other way to sort it out?
Fixes: 334
Just use the second link and report a BB fault. You will not now get response before 0800 tomorrow.
willcutforth
Fixes: 113
Hey there @Tom1994 I've tested the line and there is a potential issue so I just need you to go through all the checks for me. What @jab1 sent should help as it takes you through them all anyway.
 Will Cutforth
