Getting packet loss today
- Getting packet loss today
29-07-2014 6:37 PM
Re: Getting packet loss today
29-07-2014 7:40 PM
You can identify your present gateway here:
http://usertools.plus.net/@gateway/
In the router click on disconnect > wait about 20 seconds > click on connect.
Once you're reconnected use the gateway checker again to prove you're on a new GW.
29-07-2014 8:27 PM
That will show the packet loss from an external source, you will also need to allow ping from Wan in your router to make it work, just make sure you keep the same ip while testing!
30-07-2014 10:36 AM
If you could set up a TBB Graph as explained above, that would be handy.
30-07-2014 2:45 PM
30-07-2014 3:27 PM
Here are the following commands that you'll need via telnet:
telnet 192.168.1.254
You'll need to enter your router username and password details at this point.
service system modify name=PING_RESPONDER state=enabled
saveall
exit
30-07-2014 4:08 PM
In telnet after i put the "enabled" state it wont let me saveall, instead the command line changes to [log] = *blank* and when i type saveall it says [illegal value [saveall] for boolean type.
30-07-2014 4:12 PM
I'm not 100% on those routers unfortunately, I thought they'd be fairly similar to the Thomson/Technicolor routers.
What sort of issues do you have when gaming? Lagging? Rubber banding?
30-07-2014 4:36 PM
30-07-2014 4:38 PM
Found a guide that guides you through enabling WAN ping via the web interface. Give it a go and let us know how you get on.
http://support.zen.co.uk/kb/Knowledgebase/Broadband-Technicolor-TG-582-Enabling-'Ping'
30-07-2014 4:47 PM
That link you gave me just redirects me to http://support.zen.co.uk/kb/Default.aspx
30-07-2014 4:54 PM
30-07-2014 5:17 PM
31-07-2014 9:26 AM
31-07-2014 1:41 PM
http://www.thinkbroadband.com/ping/share/611804329944b4047f0ef6fd1249f7d9-31-07-2014.html
Not as bad as it was during the previous couple of days but I did have some issues last night while gaming as you can see from the red on the graph.
