Getting disconnections again.
- Getting disconnections again.
23-04-2010 5:27 PM
I’ve had 3 disconnections in the past few hours. My IP profile is still 6500 but my sync speed is all over the place (currently 5,280).
You can’t blame interleaving this time, it’s ON.
585v7 LOG:-
Recorded Events
Time Message
Info 03:30:24 (since last boot) FIREWALL event (1 of 1): deleted rules
Info 03:30:24 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 5280 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 16.0 dB, Up: 11.0 dB; snr Margin Down: 15.5 dB, Up: 13.0 dB)
Info 03:30:08 (since last boot) FIREWALL event (1 of 2): created rules
Info 03:30:07 (since last boot) xDSL linestate down
Info 01:17:41 (since last boot) FIREWALL event (1 of 1): deleted rules
Warning 01:17:41 (since last boot) PPP link up (Internet) [87.113.110.188]
Info 01:17:40 (since last boot) PPP CHAP Chap receive success : authentication ok
Info 01:17:40 (since last boot) PPP CHAP Receive challenge (rhost = PTE-AG2)
Info 01:17:40 (since last boot) PPP CHAP Receive challenge (rhost = ERX10.Birmingham3)
Info 01:17:12 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7264 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 15.0 dB, Up: 10.0 dB; snr Margin Down: 15.0 dB, Up: 24.0 dB)
Warning 01:17:07 (since last boot) PPP link down (Internet) [87.112.164.204]
Info 01:17:01 (since last boot) xDSL linestate down
Info 01:16:39 (since last boot) FIREWALL event (1 of 1): deleted rules
Info 01:16:39 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 5280 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 16.0 dB, Up: 11.0 dB; snr Margin Down: 15.5 dB, Up: 13.0 dB)
Info 01:16:24 (since last boot) FIREWALL event (1 of 24): created rules
Info 01:16:23 (since last boot) xDSL linestate down
Info 00:03:01 (since last boot) LOGIN User admin logged in on [HTTP] (from 192.168.1.100)
Info 00:01:13 (since last boot) FIREWALL event (1 of 6): deleted rules
Warning 00:01:13 (since last boot) PPP link up (Internet) [87.112.164.204]
Info 00:01:13 (since last boot) PPP CHAP Chap receive success : authentication ok
Info 00:01:12 (since last boot) PPP CHAP Receive challenge (rhost = pcl-ag04)
Info 00:01:12 (since last boot) PPP CHAP Receive challenge (rhost = ERX10.Birmingham3)
Info 00:00:48 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7264 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 15.0 dB, Up: 10.0 dB; snr Margin Down: 15.0 dB, Up: 23.0 dB)
Warning 00:00:27 (since last boot) DHCS server up
Info 00:00:27 (since last boot) FIREWALL event (1 of 1): deleted rules
Info 00:00:27 (since last boot) FIREWALL level changed to Standard.
Info 00:00:27 (since last boot) WIRELESS interface turned off.
Info 00:00:22 (since last boot) WIRELESS automatic channel selection done (channel = 6)
Info 00:00:15 (since last boot) FIREWALL event (1 of 1): modified rules
Info 00:00:15 (since last boot) FIREWALL event (1 of 1): created rules
Info 00:00:03 (since last boot) WIRELESS interface turned on.
Error 00:00:02 (since last boot) [CWMP: 0:00:02.510] setting cwmp defaults
Warning 00:00:02 (since last boot) KERNEL Cold restart
Re: Getting disconnections again.
23-04-2010 5:36 PM
Your local exchange needs something like this
from theRegister:
http://www.theregister.co.uk/2010/04/14/rutland_bband/
or
http://www.relay-rutlandtelecom.co.uk/
Toby
23-04-2010 6:07 PM
24-04-2010 12:17 AM
Is there anything else I need to do or will my sync speed return to 7616 by itself?
Interleaving isn't to blame this time, so what's causing the disconnections?
I've just noticed that there are quite a lot of threads on this forum relating to speed (the lack of it) issues. It there anything wrong at Plusnet?
24-04-2010 12:24 AM
You are better off restarted the modem/router during the day, 10am-3pm for the best possible chance of getting a top sync.
24-04-2010 12:45 AM
24-04-2010 1:03 AM
Quote from: Vip3r 10am-3pm for the best possible chance of getting a top sync.
I'd second this, if you can use the weekend -- it should only need doing once....
Chris
24-04-2010 10:57 AM
How much longer do I have to put up with this? I first reported this fault on the 27th March.
Here’s my latest log:-
Recorded Events
Time Message
Info 03:03:07 (since last boot) FIREWALL event (1 of 1): deleted rules
Info 03:03:07 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 7040 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 15.0 dB, Up: 10.0 dB; snr Margin Down: 15.0 dB, Up: 22.0 dB)
Info 03:02:48 (since last boot) FIREWALL event (1 of 1): created rules
Info 03:02:48 (since last boot) xDSL linestate down
Info 02:59:16 (since last boot) FIREWALL event (1 of 7): deleted rules
Info 02:59:15 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 5280 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 15.0 dB, Up: 10.0 dB; snr Margin Down: 15.5 dB, Up: 13.0 dB)
Info 02:58:57 (since last boot) FIREWALL event (1 of 24): created rules
Info 02:58:56 (since last boot) xDSL linestate down
Warning 00:00:59 (since last boot) PPP link up (Internet) [87.115.97.245]
Info 00:00:59 (since last boot) PPP CHAP Chap receive success : authentication ok
Info 00:00:59 (since last boot) PPP CHAP Receive challenge (rhost = pcl-ag02)
Info 00:00:59 (since last boot) PPP CHAP Receive challenge (rhost = ERX10.Birmingham3)
24-04-2010 4:57 PM
Thank you.
24-04-2010 5:03 PM
Your problem is that the default noise margin is too high and until you find out what is causing the problem of disconnections it is unlikely to reduce
24-04-2010 5:57 PM
24-04-2010 6:10 PM
Quote from: Oldjim Your problem is that the default noise margin is too high...
Quite normal for a 16dB attenuation isn't it? Checking previous threads it seems it's always been around 15dB downstream margin, and the sync was over 8000.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
24-04-2010 6:18 PM
No it isn't and the upstream noise margin is surprisingly low as well
Quote Info 02:59:15 (since last boot) xDSL linestate up (ITU-T G.992.1; downstream: 5280 kbit/s, upstream: 448 kbit/s; output Power Down: 19.5 dBm, Up: 11.5 dBm; line Attenuation Down: 15.0 dB, Up: 10.0 dB; snr Margin Down: 15.5 dB, Up: 13.0 dB)
24-04-2010 10:33 PM
What are you two on about? I don’t understand. Is there anything wrong with my setup? Is there something I have to alter?
I was told that the figures were correct for such a short line (about 250m).
I’ve changed all the cables, filter, modem and I’m plugged directly into the back of the BT socket. Interleaving has been switched back ON (personally, I don’t think interleaving being switched OFF had anything to do with the disconnections in the first place).
My IP Profile has just dropped to 4500.
24-04-2010 11:44 PM
This is a very good place to start http://www.kitz.co.uk/adsl/index.htm
