Getting back on ADSL2+
spark119
Hello
I have had a very stable connection over many days with a download speed of 17Mbps so i assume i was on ADSL2+ as the router showed the 992.5 standard After some unfortunate disconnections while re-organising the room the router is in it has reconnected but the speed has dropped to 6mbps and the standard now reads 992.1. S/N ratio is also high at 8/15.3 it normally sits at something like 3/8 which i am aware is low but it seems to work. My IP profile from the BT speed test is 7.17 it is normally 17 or higher
The question is how do i get it back up to its previous speed ?
Mark
Fixes: 181
Re: Getting back on ADSL2+
I'm just running a few tests on your line.
[edit]
Can you try retesting the speed now?
 Matthew Wheeler
spark119
Hi Matthew
Thamks for checking speed test results are still showing 7 but router now reports a 992.5 connection
with a bandwidth of 1.2 up and 21.2 down which is back to what it was.
Can you post a radius graph as I think it was connected for a long time before the recent problems and  I am wondering how long it was.
Mark
spark119
Still only getting 7 Mbps yet synced at 21.2 I have tried to do a bit wholesale test but it keeps failing the further diagnostics so I can't get the IP profile.
any ideas
Mark
Plusnet Staff
Plusnet Staff
Fixes: 116
I can confirm you're still provisioned on ADSL2+, and your router is in sync at 21 Mbps.
Downstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
21 3.1 0 N/A 150043 21243
Here's a copy of your radius graph. A bit choppy on Tuesday but pretty stable since then.
Are you using a wired or wireless connection? Can you also try a reboot of your router as well please?
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
