General shout out for.......HELP
- Re: General shout out for.......HELP
06-12-2007 2:12 PM
+ aiming to go wireless (children have laptops in their rooms) and I would want mine to be useable throughout house. Anyone else got that kind of set up? Plusnet supply gear?? How much??..........HELP!!
If replying remember I'm a bit of a luddite.......and getting ludditetier!!
06-12-2007 2:13 PM
Do you know what sort of modem it is? Is it a Voyager 105?
06-12-2007 2:46 PM
All you need to do is to persuade it to connect to the kiddies wifi.
Perhaps a Vista expert can help you.
06-12-2007 2:55 PM
06-12-2007 3:59 PM
It seems that Vista cannot see some USB modems.
Went out and got him a cheap router and all is now well.
Edit:- Off topic but. Just noticed that peoples post count has now been made to inlude those from the old forums.
Seems like Colin has done a good job.
06-12-2007 5:40 PM
Linky To BT
If your machine is 64 Bit then make sure you get the correct driver.
Regards
Jeff
08-12-2007 10:23 AM
08-12-2007 11:08 AM
08-12-2007 11:38 AM
You can purchase a Voyager 2110 (a 4-port wireless router) from us, at a cost of £50, or alternatively you can pick up routers fairly cheap from some online retailers.
08-12-2007 12:53 PM
A router needs no setup disk and is not tied to any specific Operating System and needs no drivers - so that when you dump Vista the router will still work.
A router also tends to give a more stable and sometimes faster connection and can connect to multiple computers simultaneously.
08-12-2007 1:15 PM
08-12-2007 7:03 PM
If you don't mind the router being a reconditioned one, then I don't think you can complain for the money!
The one I got from them was fine.
09-12-2007 11:15 PM
10-12-2007 6:13 AM
Voip means you get 240 minutes of free calls every month from
plusnet why lose them?
You can make calls without leaving the computer on and it like having an extra telephone line free no line rental and any UK std code you want
puddy
10-12-2007 11:09 AM
