Gateways down? or graph problem?
Anotherone
Champion
Fixes: 21
27 REPLIES 27
Kelly
Fixes: 9
Re: Gateways down? or graph problem?
That's weird!  Still plenty of people connected!
Having a look.
Kelly Dorset
Ex-Broadband Service Manager
Kelly
Fixes: 9
Unexpected side effect of that config change.  They are working to restore that graphing now.
Kelly Dorset
Anotherone
Champion
Fixes: 21
Not working too hard then  Shocked
Kelly
Fixes: 9
Sounds like a bug.  Asking the vendor.
Pah, hardware.  Who needs it eh?
Kelly Dorset
Anotherone
Champion
Fixes: 21
I'll refrain from commenting further  Cheesy
houlton23
Any progress? Smiley
chrispurvey
As far as I was aware this was it had been rectified, I'll chase this up.
MsDizzie
I had a disconnection this morning (11am) so I went to check the Network Performance Graphs and saw that the Collated Users graph still hasn't been fixed  Roll_eyes
http://portal.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml
Kelly
Fixes: 9
This won't fix itself for a while.  Basically, we need to reset something on the switches, but the command we need to run could disconnect everyone on that switch.  That's a lot of people to be disconnected in one go, so it will be gradually done.
Kelly Dorset
MsDizzie
Fairy nuff! (Pity it couldn't have been scheduled on April 1st, you might have got away with it  Wink )
Thanks for the reply Kelly
houlton23
Looks like this is fixed now, but I was just wondering why pcl-ag07 and pcl-ag08 have 23-24k users whilst all the other gateways have 37-40k users?
Alex Smiley
Finguz
Where can we see how many users are connected to each gateway?
houlton23
Anotherone
Champion
Fixes: 21
Yes, the last one, pcl-ag02, was done early this morning.
As far as the number of users, I'd guess it has something to do with the number of "end-points" but Kelly or Dave would be the ones to explain that - I'm not that knowledgeable in that area  Sad
