Gaming useage?
Kazbah
Gaming useage?
What is this classed as? According to my internet useage i have used 15mb on gaming?? whats that mean?Huh
1 REPLY
Fixes: 223
Re: Gaming useage?
The usage type is worked out by the traffic management tools, so if it thinks your traffic is gaming that is what it will show up as.
This isn't to say the usage count isn't correct, it will be - just possible mis-identification of traffic.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
