Gaming problems, is it down to my Internet or is it down to the 2704n router
- Gaming problems, is it down to my Internet or is i...
Re: Gaming problems, is it down to my Internet or is it down to the 2704n router
21-02-2016 11:16 PM
21-02-2016 11:34 PM
23-02-2016 1:13 PM
When I am on my xbox one (through a wired connection) and playing call of duty, they have a menu where you can see your ping time and those numbers can be quite high up to 330 ms.
my latency is 160 and above never below this is there a reason my latency is so high?
Thanks for helping me with all this.
u0_a191@degaslte:/ $ ping ntp.plus.net
PING ntp.plus.net (212.159.6.10) 56(84) bytes of data.
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=1 ttl=60 time=15.4 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=2 ttl=60 time=19.1 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=3 ttl=60 time=25.1 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=4 ttl=60 time=24.3 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=5 ttl=60 time=25.1 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=6 ttl=60 time=17.4 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=7 ttl=60 time=20.6 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=8 ttl=60 time=29.4 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=9 ttl=60 time=24.1 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=10 ttl=60 time=25.0 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=11 ttl=60 time=20.7 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=12 ttl=60 time=23.7 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=13 ttl=60 time=38.3 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=14 ttl=60 time=23.6 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=15 ttl=60 time=27.5 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=16 ttl=60 time=51.2 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=17 ttl=60 time=25.9 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=18 ttl=60 time=17.2 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=19 ttl=60 time=28.1 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=20 ttl=60 time=23.3 ms
64 bytes from cdns02.plus.net (212.159.6.10): icmp_seq=21 ttl=60 time=26.0 ms
23-02-2016 11:20 PM
Whilst there is still a fair bit of variation in the ping/latency times to ntp.plus.net there are a couple of quite low ones which suggest Interleaving is turned off on your line, which you need for the best experience. But I think it would be a good idea if we had some CRT input to check your WBC Profile and make sure it is off, also an xDSL status check to see what errors and your line ILQ is like. It might be that the error rate is a bit on the high side and a slightly higher SNRM may help.
I mentioned about the low ping times - 15.4, 17.4, 17.2 which will any event depend of your exchange location relevant to the Gateways or PoP. What exchange are you on?
When on CoD the actual ping that you get will depend on the location of the server hosting the game as well as the ping time of their connection.
24-02-2016 7:52 PM
I have no idea what exchange I am on is there a way of finding out? Also could I ask 2 hat crp input is? Sorry I'm not very tech savvy at all lol.
Yeah I get you with cod it all depends on the host of the match can I ask what causes latency being so high? I have always had high latency is that all to do with ping times?
I have got a question submitted but response times from plus net staff are ultra slow.
24-02-2016 8:11 PM
I've had another idea as well, but I want to research it a little more, I'll try and post late tonight or in the morning.
24-02-2016 8:31 PM
The question number is #119027789.
I shall PM you my first 5 digits now.
25-02-2016 9:17 AM
SNR Margin: 3.3
Speed: 944 15636
Indicative Line Quality: A
Mean Time Between Errors Downstream (Seconds): 104
The SNR was down at a target of 3db, I can see the MTBE was lower than ideal so we've increased the target SNR to 6db. This was done yesterday, so it's worth monitoring over the next 24 hours to see how the line performs.
25-02-2016 10:04 AM
25-02-2016 11:02 AM
25-02-2016 11:08 AM
25-02-2016 11:16 AM
25-02-2016 11:21 AM
25-02-2016 11:28 AM
26-02-2016 10:10 AM
I just wondered how everything was looking today? I wasn't able to get onto my xbox one yesterday as my son smashed our television yesterday morning sob sob. I'm getting a new telly today so should be able to test how everything is going from a gaming point of view.
Thanks for your support Anotherone, yes lag really is the biggest issue, it makes the difference on whether I can have fun or not doing a hobby I enjoy, and that's mostly why I need Internet at home.
Also can I ask am I on ADSL2+ ?
