Gadually Sinking Speeds
- Gadually Sinking Speeds
27-02-2009 11:50 AM
Can anything be done to get the line profile put back to a value nearer to my DSL connection rate?
results below:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 3776 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 1827 kbps
Re: Gadually Sinking Speeds
27-02-2009 12:59 PM
Edit: fixed link
27-02-2009 1:28 PM
BT speedtest results are as given in my post.
27-02-2009 3:56 PM
27-02-2009 5:33 PM
27-02-2009 7:28 PM
28-02-2009 12:24 PM
Please advise,
Thanks,
Mikko
28-02-2009 6:06 PM
28-02-2009 6:38 PM
06-03-2009 9:36 AM
Mikko
06-03-2009 10:21 AM
The profile should pick up again in the next 2-3 days.
06-03-2009 3:18 PM
07-03-2009 5:56 AM
07-03-2009 11:20 AM
I was remembering what someone said when I first went on 'up to 8 mbps' - " the green option is to turn of your router overnight". .
07-03-2009 3:49 PM
Generally speaking if you switch on between an hour after sunrise to an hour before sunset when noise tends to be lowest, you'll get the higest sync speeds. If you are on a 6dB Target SNRM however, there may be another trade off, if your noise levels go very low after dark (causing loss of sync), if may be better to sync when noise levels are higher so the margins don't drop as low.
