G-Fast and standard fibre???
- Re: G-Fast and standard fibre???
28-09-2014 2:28 AM
Not sure where to post about this?
I read a short item that BT are testing a new 'system' that will use the current infrastructure (fibre and last leg copper to the house???) to get up to 800mbps download (I cannot recall what was said about upload but it was fast!).
So do any of the PN guys 'n gals know anything about this and are there any plans for its testing and eventual rollout with PN.
A simple surmise is that if G-Fast goes mainstream 'standard' fibre costs will drop to ADSL levels.........I wish
Message 1 of 9
(1,854 Views)
8 REPLIES 8
28-09-2014 7:25 AM
News article over at ISPreview - http://www.ispreview.co.uk/index.php/2014/09/bt-boast-1000mbps-g-fast-fttdp-broadband-technology-pot...
Personally I don't see BT rushing to roll out G.fast(of their own accord) after they've just spent a few pounds on VDSL.
Message 2 of 9
(864 Views)
28-09-2014 10:31 AM
This is years away from being implemented.
Message 3 of 9
(864 Views)
28-09-2014 9:57 PM
isn't the next upgrade where they'll run fibre to the pole, so the copper length gets shorter again?
i'm sure i read that somewhere in the past couple of days.
Message 4 of 9
(864 Views)
28-09-2014 10:04 PM
Quote from: PLan after they've just spent a few pounds on VDSL.
Well it was taxpayers and BDUK's money so not sure why they would use that - they spent very little.
and it would be again no doubt. Still when Farage is in power and all the refugees have been kicked out we might have the money to do it.
Message 5 of 9
(864 Views)
28-09-2014 10:09 PM
FTTdp is where you shorten the end copper distance by using a fibre fed micronodes - g.fast is a technology that allows you to transmit data at far superior speeds over copper.
The two are different technologies, but would work well together. It's going to be a cost issue though as the difference between FTTH and FTTdp is marginal.
Message 6 of 9
(864 Views)
29-09-2014 12:07 AM
If I look at it on the system I have you are right.
Message 7 of 9
(864 Views)
29-09-2014 1:19 AM
Quote from: petecov44 Well it was taxpayers and BDUK's money so not sure why they would use that - they spent very little.
Wasn't BT's investment around £2.5 billion?
Message 8 of 9
(864 Views)
29-09-2014 7:48 AM
Was it? Sorry I thought it was less. I am sure even that is pocket change to BT
Message 9 of 9
(864 Views)
