Funny fault
- Re: Funny fault
Funny fault
29-05-2015 3:42 PM
I followed a googled article and used tracert in command mode and after 7 hops it started to time out, with the final destination being at a plusnet address.
Fortunately we have two accounts between son and me with his working fine so I could get by.
Plusnet started to check it out and I was advised that it was an Openreach problem. The Openreach engineer phoned me the next morning but by then it was working again and we decided it would be a waste of his time coming out as he would get on the ferry at 10:00am and not get back until 5:00pm.
Of course the fault returned but it also affected the second account in the same fashion. Both accounts came back on again later but the question is did Plusnet repair it or is it an intermittent fault.
It would be handy to know
Re: Funny fault
29-05-2015 5:40 PM
I'm going to be honest, I'm a bit lost as to what this might have been so can't really say either way where the issue lay.
Re: Funny fault
20-09-2015 12:51 PM
Just had 5 days with no problems and now the fault is back again! No connection to any site starting with 212. Openreach said that they had rectified a fault in the local exchange that may have been the cause a few days ago.
Could the fact that I upload a couple of images, total about 70kb per minute affect anything?
Just swapped router to another Draytek 2820n but no difference.
Could it be a fault affected by that particular model of router? I have some spare Belkin routers which I could try, or would I be wasting my time?.
I
Re: Funny fault
20-09-2015 1:04 PM
Quote from: jorvikmik No connection to any site starting with 212. Openreach said that they had rectified a fault in the local exchange that may have been the cause a few days ago.
Undertaking tracert diagnostics (or pathping) to somewhere like plus.net would be useful here.
212.*.*.* is a massive range of addresses - a refinement of this (for example 212.159.*.* one of PlusNet's subnets) would be very helpful.
I very much doubt that any thing done in the local exchange would impact traffic routing from you to the internet, as all onward routing is performed on PlusNet's premises. Anywhere you try to connect to have to go through PlusNet's gateway and be routed onwards.
Re: Funny fault
21-09-2015 11:52 AM
Re: Funny fault
22-09-2015 9:43 AM
Re: Funny fault
25-09-2015 12:58 PM
