Full Service System List 8.C.M.0 FTTC Required
- Full Service System List 8.C.M.0 FTTC Required
22-12-2013 4:49 PM
Hi, all
Anybody got a full default/unchanged full service system list for a TG582n 8.C.M.0 FTTC please. I've got myself into a pickle and lost my original. I think the command is as follows for the full list. The list is a bit long winded
service system list expand=enabled
Message 1 of 6
(2,480 Views)
5 REPLIES 5
Re: Full Service System List 8.C.M.0 FTTC Required
22-12-2013 6:26 PM
Yes that command is correct or just "service system list" for a briefer version.
The following link will show the default settings, look in the
[ servmgr.ini ] section. The settings are unlikely to have changed between firmware versions.
http://beusergroup.co.uk/technotes/index.php?title=582n_default_config
Message 2 of 6
(589 Views)
22-12-2013 8:55 PM
Cheers npr,
Perfect
Perfect
Message 3 of 6
(589 Views)
22-12-2013 9:06 PM
I think the exact setup of that servmgr.ini section is somewhat specific to O2, considering all those IP addresses added for remote access to various services, and also the wan ping responder appears to have been enabled.
Message 4 of 6
(589 Views)
22-12-2013 9:26 PM
It's listed as "default config"----- it clearly is not
Those IP addresses and ping responder settings are not the default for O2.
Message 5 of 6
(589 Views)
22-12-2013 10:03 PM
I'm only using it as a guide. So all good
@ejs i think the ping responder is enabled, but for lan only
Also i didn't see earlier that all none standard settings have a label like so "(administratively) disabled"
14 PING_RESPONDER icmp 8
Description................ ICMP echo responder
Properties................. server
Attributes................. state aclip aclif aclifgroup map log qoslabel routelabel natpmweight
User Managed Attributes.... state aclip aclif aclifgroup log natpmweight
Attribute Values :
State...................... enabled
QOS Label.................. None
Route Label................ None
NAT Portmap Weight ........ 30
Ip Access List............. any
Interface Access List...... any
Interface Group Access List lan
Map List................... 8
Logging.................... disabled
Message 6 of 6
(589 Views)
