Full Fibre
Alfaman
Full Fibre
Hi All,
I forgot that my contract had expired so I've veen paying full price - almost £60 for a FTTC connection for quite some time 😞.
Openreach have installed full fibre poles on my estate but when I look at offers and upgrades on Plusnet, I only get a part fibre option. Why is this?
Alfaman
81 REPLIES 81
Fixes: 380
Re: Full Fibre
@Alfaman Does Full Fibre show as available on this page? https://www.broadbandchecker.btwholesale.com/#/ADSL
Ascreenshot of the full detail, Excluding personal info, would help.
Alfaman
Re: Full Fibre
Ah ok it doesn't but the poles were only put up a couple of weeks ago so maybe it'll take some time to feed through? It says at the bottom that FTTP is not available. Thanks for your help!
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability WBC SOGEA Availability
High Low High Low
VDSL Range A (Clean) help 40.4 27 8.4 6.1 22.4 Unavailable Available
VDSL Range B (Impacted) help 39.8 22.4 8.3 5.9 17.6 Unavailable Available
G.fast Range A (Clean) help -- -- -- -- -- Unavailable --
G.fast Range B (Impacted) help -- -- -- -- -- Unavailable --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 1000 220 -- Available --
Other Offerings Availability Date
VDSL Multicast Available
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal Y
SOADSL Restriction N
Fixes: 115
Re: Full Fibre
@Alfaman
It can take time for the backbone network to be commisioned. Does the pole that serves your house have a box that looks like this.
https://community.plus.net/t5/image/serverpage/image-id/62134i68567DDA298F3522/image-size/large?v=v2...
In the meantime I would consider recontracting now just to get your price down. You can upgrade to Full Fibre at any time.
Note that which ever way you go your lose your landline if this matters.
Fixes: 380
Re: Full Fibre
How does your current phone/internet get to your house?  I understand the FTTP is conveyed the same way.
Alfaman
Re: Full Fibre
Hi yes, the pole has a black plastic thingy at the top which looks like the picture on the link you've sent. So you recommend recontracting now at the part fibre rate until the pole is commissioned? It's strange that I received an email from Openreach on the 4th April   saying "Congratulations, you can now get Full Fibre on the Openreach network" followed by my house address.  (I'd registered with Openreach to be kept informed when full fibre was available)
Alfaman
Re: Full Fibre
Underground through a duct and I already have FTTP. But the duct only extends part way up the road the rest of the cabling is not ducted and Openreach say it's too expensive to dig it all up which is wht they have installed the poles. Bit of an eye sore, I must say,,,
Fixes: 380
Re: Full Fibre
@Alfaman I'm a bit confused. If you are already on an UG feed, the fibre cable should follow the same route from the chamber. If you already have FTTP, I'm even more confused.
Fixes: 115
Re: Full Fibre
@Alfaman
I assume you meant FTTC in your last post.
Full Fibre is coming but when is the question. It could be next week, it could be a couple of months. If you recontract now on SOGEA you reduce your bill while you wait. Full Fibre 74 is the slowest speed and is usually the same price as SOGEA.
As I say you lose your landline but that's happening anyway in the near future.
Alfaman
Re: Full Fibre
Hi Yes, we on the estate are confused as well  - we  all thought  that the full fibre installation  would follow the underground route. But we all received a letter from Openreach a few months ago  saying that they had decided to install full fibre via the telegraph poles. Couldn't get a clear answer from the pole installers they just said they installed the poles where they had been told. But I saw an Openreach engineer walking about and had a chat with him - he said that the underground ducting on my road was very short - the rest of the phone lines were just buried in the ground (difficult to believe🤔)  and they would have to dig up 100 metres of road to install the ducting for the fibre  which would be too expensive hence the pole option. So at the moment I have FTTC (18MbS)  via the underground duct, but as you know by 2027 all the underground copper cabling will be decommissioned and we'll all have to be on a full fibre connection, which is why I was trying to get a full fibre FTTP connection via Plusnet seeing as the pole is just outside the house.  But if you think the pole commissioning will take too long, maybe I should do what you suggest and get onto a part fibre contract asap...and upgrade to full fibre sometime next year?
Alfaman
Re: Full Fibre
Yes sorry FTTC at the moment...
Fixes: 380
Re: Full Fibre
Ah, so your cabe is Direct In Ground for most of its length - that explains the change to an OH feed.
Fixes: 115
Re: Full Fibre
@Alfaman
No one knows how long it'll take to commision the fibre backbone.
You could phone the PlusNet Customer Options Team on 0800 013 2632 and ask if it's worth jumping to SOGEA now with full fibre so near. Only you can decide.
The copper network is not being decommisioned. It's the PSTN service that runs on it that's going. SOGEA will continue to use the "last mile" of copper from the to a property for a good few years.
Those on ADSL have a problem as this needs the phone line but various solutions are being put in place for those users.
Alfaman
Re: Full Fibre
All good I think I'll just sign on tomorow on a contract about £ 23 I think and see what happens with the pole backbone  commissioning. Many thanks for all your help - you've certainly cleared things up a lot and I now know what the situation is. Bit different to when I was a student and we used to program IBM mainframes with punched cards - every line of code was on a single punched card and the program consisted of hundreds of punched cards in order which were fed into a punched card reader! 🙄 Pre internet age.........
RadioFox
Re: Full Fibre
@Alfaman Ahh...the mention of punched cards takes me back to my 6th form years at school in the 70's. We had 2 card punch machines, like small mechanical typewriters to punch our cards. I vaguely remember there were different coloured cards for the start & end, & blue for the main program. We programmed in Fortran IV. Our teacher would take them to the local polytechnic, then go back a few days later for the printouts.
