Frustrating Concentrator not reachable error
cyper
It is very frustrating that when my connection disconnects it doesn't connect back up immediately. Just now the connection dropped and I had to restart my modem+router like 3 times. And this is not the first time it happens - it actually happens more often that I like.
I was with Bethere before and for the 5 years I was their customer I had less disconnects than for 4 months with PlusNet. And I don't remember having to wait before I can connect again.
krs360
Re: Frustrating Concentrator not reachable error
There's a time out on dropped PPPOE connections, don't quote me on this but it's recently been lowered... used to be around 6 minutes. Have a little more patience and it should sort itself out within a few minutes.
Cheers,
Ben.
cyper
I have found the cause of today's disconnects and I can't figure out why would that happen. It is unbelievable.
I downloaded this VOIP program: http://www.voxox.com/ and I swear to god whenever I start it my router looses power. It may sound crazy, but I am 101% sure that is the cause.
It happened 3 times today + 2 more times while I was on the phone with customer support. I even told the guy because I grew suspicious that I think this program makes my connection drop. He said that is impossible.
Well after I finished with the call I decided not to start the program again and out of curiosity just 5 minutes ago I started it and my router rebooted.
Any logical explanation here?
Fixes: 6
Could it be uPNP causing it?  ie the VOIP program sending out a uPNP request and a faulty router/buggy router firmware is crashing the router?
Phil
Fixes: 71
I believe Voxox is a multi-purpose program with VoIP just one of its applications. Wondering if it swamps the router with repeated 'anything for me' requests which causes table overflow and a reboot? In that case the router software should handle a full table more elegantly, but …
Do you have a different model of router to try?
David
Fixes: 5
Android or iOS?
Kelly Dorset
Broadband Service Manager
Fixes: 166
Quote from: cyper
I'm going to test this later today on an Android handset via a 582n router and see what happens.
 Chris Parr
 Plusnet Staff
Fixes: 166
I've tried several times to sign up for this service but the confirmation SMS isn't coming through, so at the moment I'm not able to test. I'll keep trying.
 Chris Parr
 Plusnet Staff
cyper
Quote from: pjmarsh
Phil
No idea really, but UPNP is on. I uninstalled it obviously, because it's a piece of c**p program.
Quote from: spraxyt
I do, but to be honest it is not worth the effort. Plusnet are sending me a new router, because they think mine is faulty. When I swap them I might out of curiosity  install it again and try.
Quote from: Kelly
Android or iOS?
Windows 7 Professional x64
Quote from: Chris
Quote from: cyper
Never tried on my phone. I ran it on my Windows machine.
Quote from: Chris
Mine came immediately.
