Frustrating Concentrator not reachable error
- Re: Frustrating Concentrator not reachable error
31-10-2013 1:57 PM
I was with Bethere before and for the 5 years I was their customer I had less disconnects than for 4 months with PlusNet. And I don't remember having to wait before I can connect again.
31-10-2013 9:40 PM
Cheers,
Ben.
01-11-2013 12:50 AM
I downloaded this VOIP program: http://www.voxox.com/ and I swear to god whenever I start it my router looses power. It may sound crazy, but I am 101% sure that is the cause.
It happened 3 times today + 2 more times while I was on the phone with customer support. I even told the guy because I grew suspicious that I think this program makes my connection drop. He said that is impossible.
Well after I finished with the call I decided not to start the program again and out of curiosity just 5 minutes ago I started it and my router rebooted.
Any logical explanation here?
01-11-2013 8:15 AM
Phil
01-11-2013 11:36 AM
Do you have a different model of router to try?
01-11-2013 11:42 AM
Ex-Broadband Service Manager
01-11-2013 11:43 AM
Quote from: cyper
I'm going to test this later today on an Android handset via a 582n router and see what happens.
01-11-2013 3:13 PM
01-11-2013 3:52 PM
Quote from: pjmarsh Could it be uPNP causing it? ie the VOIP program sending out a uPNP request and a faulty router/buggy router firmware is crashing the router?
Phil
No idea really, but UPNP is on. I uninstalled it obviously, because it's a piece of c**p program.
Quote from: spraxyt I believe Voxox is a multi-purpose program with VoIP just one of its applications. Wondering if it swamps the router with repeated 'anything for me' requests which causes table overflow and a reboot? In that case the router software should handle a full table more elegantly, but …
I do, but to be honest it is not worth the effort. Plusnet are sending me a new router, because they think mine is faulty. When I swap them I might out of curiosity install it again and try.
Quote from: Kelly Android or iOS?
Windows 7 Professional x64
Quote from: Chris
Quote from: cyper
Never tried on my phone. I ran it on my Windows machine.
Quote from: Chris I've tried several times to sign up for this service but the confirmation SMS isn't coming through, so at the moment I'm not able to test. I'll keep trying.
Mine came immediately.
