Fritzbox 7390 help
- Fritzbox 7390 help
Fritzbox 7390 help
02-06-2013 8:35 PM
I put xxxxxx@plusdsl.net for my user name and my member centre password as the password. I have the grey cable with the grey adapter into the bt dsl socket. Did not bother with the black cable as it has the wrong end for the bt socket.
I have I done something wrong fritzbox users?
Re: Fritzbox 7390 help
02-06-2013 8:44 PM
Are you getting sync? (Either 'Overview' or Internet > online monitor page will say if you have DSL sync and whether you have Internet connection).
You may find clues under 'System > Event Log > Internet Connection'
02-06-2013 8:49 PM
Quote from: Bacardii I put xxxxxx@plusdsl.net for my user name and my member centre password as the password.
I assume you put your actual Plusnet username where you say 'xxxxx'
02-06-2013 9:00 PM
02-06-2013 9:21 PM
Have you attempted to connect in any way other than via DSL? If so, I'd recommend a factory reset (may be worthwhile anyway).
After reset (follow exactly step by step - instructions should be correct for Fritz OS 05.51 and previous version - sorry, can't remember the exact previous version number):
Click 'Internet > Account information'
Under 'internet service provider' select 'Other internet service provider'
Under 'Line' select 'Connecting to a DSL line'
Enter your account information in the boxes
Under 'Connection settings' click on 'Change connection settings' then select 'Maintain Permanently' and tick 'Use VLAN' and enter '101' in the VLAN ID box. Under 'DSL ATM Settings' select 'Set manually' and ensure that PPPoE is selected under 'Encapsulation' (The default values of 1 & 32 can just be left in VPI and VCI).
Tick 'Check the Internet connection after "Apply" has been clicked' and click 'Apply'
What happens next?
02-06-2013 9:50 PM
I am about ready to put it in the bin.
Thanks for help
03-06-2013 8:29 AM
Are you using the DSL cable that came with the 7390 ? and do you have it the right way round ? ( page 22 of the manual )
Have you tried it with/without the adapter ?
03-06-2013 11:46 AM
Quote from: Bacardii Did not bother with the black cable as it has the wrong end for the bt socket.
Where did you buy the FB?
They use a different cable for UK versions (mine was an 'International' version but supplied with a separate UK cable).
03-06-2013 9:08 PM
Cheers
jim:quote
04-06-2013 12:16 AM
I imagine a euro cable will only have the outer pair, perhaps?
04-06-2013 8:15 AM
04-06-2013 8:29 AM
It's got to be worth a try, and it can't do any harm.
Quote Can I just use the cable that came with the openreach modem?
04-06-2013 8:33 AM
Regarding version: what numbers are printed on the label under the unit?
04-06-2013 5:20 PM
30-08-2013 11:19 PM
I`ve got a Fritzbox 3390 and had a same problem as above.
For the first attempt I could not connect directly via the phone line but done a factory reset and followed the initial setup did not help either.
After I followed the setup below and it looks like the manual VLAN 101 setting helped. (All of the other settings were correct automatically).
Before I was getting an error message something like "the ISP not responding for the PPPoE pings, Internet connection could not be established".
Thanks for this guide, really helped me!
Quote from: w23 First, I assume your FTTC line is working OK (connects with BT modem).
What happens next?
