Hi all,
I'm trying to setup my Fritz Box 3390 with port forwarding for my PS4.
Whilst I have UPnP enabled I would still like to open the correct ports to ensure an open NAT - I'm already using exposed host (DMZ) for my Xbox One.
Here is an example for the PS4 opening port 443:
Port Forwarding enabled for: Other Applications
Name: PS4 TCP 443
Protocol: TCP
From Port: 443 through port 443
Computer: PS4
IP Address: 192.168.0.13
To Port: 80
It's the last bit "To Port" I'm confused about.
It always defaults to 80 but shouldn't I changed it to 443 for the example above?
If so what would I enter in the To Port part for a range of ports e.g. 10070-10080?
Thanks for looking in.
