Frequently losing internet
- Frequently losing internet
11-12-2014 8:56 PM
All green lights are on on the router but internet access on devices ceases. This can be from the start or part way through a browsing session. Usually sucessfuly resolved by turning router off for a few minutes / hours but that's obviously far from ideal fro so many reasons.
Any advice welcome or do I simply raise a ticket?
BTW I don't know if this is significant but that little spinny thing in the top left hand corner of the tab is nearly always spinning whereas it used to stop after loading the page.
Message 1 of 2
(514 Views)
1 REPLY 1
Re: Frequently losing internet
12-12-2014 9:27 AM
Hi there.
Sorry to hear your having issues with your connection.
I've included a graph of the drops below.
Our testing isn't showing any particular issues so I'd recommend going through our faults troubleshooter using the link below.
http://faults.plus.net
If you have any further questions feel free to let us know.
Message 2 of 2
(305 Views)
