Frequent(ish) sync losses
- Re: Frequent(ish) sync losses
11-09-2008 7:29 PM
11-09-2008 8:16 PM
have a look here http://community.plus.net/forum/index.php/topic,67895.0.html
I had a simular problem, and I do not think it is entirely corrected yet.
My thoughts are that overhead lines, lots of rain water also causing frequent disconnects.
IAn
11-09-2008 11:07 PM
All cables should be away from any mains if possible failing that they should pass at right angles not go along side with the mains
14-09-2008 7:55 PM
14-09-2008 9:06 PM
14-09-2008 10:22 PM
15-09-2008 8:27 PM
No obvous fault was found on the automated faults checker, but it could not complete anyway. I have moved the router from the attic, and connected it directly into the ADSL filtered faceplate I have. My usual setup is to have the router connected to this faceplate via Cat5e cable running to the attic, and termiated in an RJ11 socket box, got all this kit from Clarity, the cable is http://www.clarity.it/xcart/product.php?productid=16139&cat=250&page=1
I suppose the cable could be going south, as a section of it, does run under carpet, at a door junction, and its just possible that the constant walking could have damaged it, even though its right under the doorplate. Anyhow, if it remains stable with this, then it must be this cable, damaged somewhere. If not, then I will remove the faceplate, and try for a couple of days in the test socket, with a microfilter so I can still use the phone. If this does not work, I do not have another router, would PlusNet lend me one, to check if the router is on its way out.
Edit... Plus are going to turn on interleaving, but I was sure it was already on, but cant find anywhere in the router pages that tells me. Does anyone know where it is on a speedtouch 585V6?
Currently it says
DSL Connection
Link Information
Uptime: 0 days, 1:10:44
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 6.016
Data Transferred (Sent/Received) [KB/MB]: 790,00 / 2,51
Output Power (Up/Down) [dBm]: 11,5 / 19,5
Line Attenuation (Up/Down) [dB]: 27,0 / 43,0
SN Margin (Up/Down) [dB]: 24,0 / 5,0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 827.952
CRC Errors (Up/Down): 0 / 36
HEC Errors (Up/Down): 0 / 36
15-09-2008 9:35 PM
16-09-2008 10:29 AM
It's not *that* uncommon on a Monday, as this is our busiest evening of the week. Gold drops are more likely on Mondays, which might result in a bit of a slowdown in speeds.
16-09-2008 1:00 PM
Can you tell if interleaving was already on my line or not. Last night seemed quite stable sync wise, and I do wonder if the CAT5 cable has got a bit damaged. Any ideas on how to test CAT5 cable?
16-09-2008 1:04 PM
Interleaving is currently set to auto, but I can turn it on if you want me to?
16-09-2008 7:53 PM
16-09-2008 7:55 PM
Quote Any ideas on how to test CAT5 cable?
how much money have you got?
http://www.maplin.co.uk/Module.aspx?ModuleNo=45779&C=Newsletter&U=08P10-4&T=11946872
16-09-2008 7:57 PM
17-09-2008 8:35 PM
