Frequent disconnects
- Frequent disconnects
24-01-2014 3:40 PM
Frequently it will resync at around the 6000/6100 mark but often much lower at around 5500.
[quote=Current stats:]Uptime: 0 days, 0:01:51
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 5.995
Data Transferred (Sent/Received) [MB/MB]: 25,16 / 897,30
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 25,4 / 48,0
SN Margin (Up/Down) [dB]: 6,5 / 6,3
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 11 / 0
FEC Errors (Up/Down): 0 / 41
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
I have reported a BB fault for further investigation ticket #80346673.
During the fault reporting process is asks if I have either:
used another filter - problem solved
used another filter - problem persists
haven't used another filter
there's no option to select for having NT2000 (with a built-in filter) so I have left a note to that effect in the ticket.
This is a similar issue to one I reported back in 2012
Any help appreciated.
Thanks.
Forum Moderator and Customer
Re: Frequent disconnects
24-01-2014 4:50 PM
Sorry to see there's an issue. Tests have picked up on a line fault (dis in network, i.e a physical disconnection, usually in the exchange) so I've logged a phone fault and engineers should be able to resolve that without needing to visit.
Adam
24-01-2014 4:54 PM
The same fault was reported last year by Matt as mentioned in my thread linked to above.
[quote=http://community.plus.net/forum/index.php/topic,110007.msg943533.html#msg943533]Hi Mav,
On the off chance there I just ran a check on your phone line, and it showed a fault (Dis in exchange, I think this is the contacts somewhere). I've taken the liberty of raising this for you, hope it gets things sorted. I'll put the reference on a ticket on your account and pass it through to the phone faults team.
Could it be the same fault reappearing, not actually rectified at the end of 2012 or a false reading?
Edit: Thanks for looking into this.
31-01-2014 12:16 PM
Have had a few calls from a CSC Analyst over the last few days.
The upshot being that if there was a DIS fault then it's cleared. Strangely enough, the night that I was told it was clear we had three disconnections. The CSC analyst said she would now report as a broadband fault and an engineer was booked for this morning.
He duly arrived and could find no faults within the premises so he went to the exchange and did some further tests. He then rang back to say that he had performed a 'hard SNR rest to 6dB' as he noted that the SNR had been dropping regularly which is something I had explained to CSC in my calls. The OR guy feels that any issues should be resolved but to monitor the line so, to this effect, I will run Routerstats for a couple of weeks and see what transpires.
Current stats:
Uptime: 0 days, 0:13:44
Bandwidth (Up/Down) [kbps/kbps]: 888 / 6.023
Data Transferred (Sent/Received) [MB/MB]: 29,27 / 102,95
Output Power (Up/Down) [dBm]: 12,8 / 0,0
I did ask CSC in a response to the last ticket if there was any difference to a hard reset as performed at the exchanged by OR to the SNR reset you can perform - I'd be interested to know.
On a side note one ticket reply asked me to ring in. I got a message about a 30 minute wait but was answered in less than 5 seconds
31-01-2014 12:46 PM
31-01-2014 1:33 PM
Fingers crossed, too
31-01-2014 4:02 PM
Just lost both telephone and broadband.
Don't usually lose telephone at the same time. Were more test being run your end or by OR?
03-02-2014 2:27 PM
Had another drop yesterday at around 05:00 with a resync to 5716/888.
Another drop this morning at around 06:30 for about 12 minutes and resync at 5799/888.
Just checked the TBB graph and wondering whether we should be concerned about all the red at the top since the last drop?
03-02-2014 2:36 PM
Also mentioned in some other topics
03-02-2014 2:58 PM
With the connectivity issues I've been having I wasn't looking for any other factors.
Will wait for a resolution to the above then continue monitoring my connection.
05-02-2014 2:38 PM
Currently the SNR is showing as 9.3dB.
I will keep an eye on the connection over the next few days.
