Frequent disconnects after upgrade to ADSL2+
- Frequent disconnects after upgrade to ADSL2+
26-03-2012 4:27 PM
My modem, a Netgear DG834G v3, does not flag that the line isn't working, but the internet connection isn't restored until I log into the modem and disconnect then reconnect the line. Before the switch to ADSL2+ the line was completely stable. I've tried changing the microfilter but this has had no effect. Plugging the modem into the test socket has likewise had no effect (which I would have expected as there are no other sockets connected to the line. The disconnects are unrelated to telephone use, and completely disconnecting the telephone makes no difference. My house is very close to the telephone exchange (approx 250m) and currently I'm getting 6Mb/s download and 0.64Mb/s upload speeds. Does anyone know if there are problems using the Netgear DG834G v3router with ADSL2+? I don't have another router to test the line and I'm reluctant to register the problem and risk a BT call out charge. I'd be grateful for any thoughts or suggestions.
Jim
Re: Frequent disconnects after upgrade to ADSL2+
27-07-2012 3:19 PM
27-07-2012 4:05 PM
I've checked your connection log and your line appears to be stable.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13434013586207.png" />
@mikealexander @jimj
Certain Netgear DG834 routers have issue's on ADSL2+, I would make sure you have the latest firmware. Go <a href="http://community.plus.net/library/hardware/adsl2-hardware/">here</a> to make sure you are up-to-date.
27-07-2012 4:38 PM
You can get it from http://downloadcenter.netgear.com/en/product/DG834Gv3
27-07-2012 5:20 PM
jim:quote
27-07-2012 5:27 PM
That suggests a US only and an all the rest version - however looking closely the links look the same.
14-08-2012 1:04 PM
Quote DG834v3 and DG834Gv3 Wireless ADSL Modem Router
Version 4.03.04 for North America
Version 4.01.06 for UK
Version 4.01.04 for Outside North America & UK
Published July 18, 2006
The release notes for 4.01.40 are an empty document, but I assume the higher version number means it's the latest for use in the UK with this particular model.
15-08-2012 9:16 AM
The problem didn't really go away, though line stability did improve after PlusNet investigated the issue. However I was left with download speeds much the same as I had before the line upgrade (around 6Mb/s) which seems very poor, given I'm only about 250m from the telephone exchange. I thought I was on the latest router firmware but realised I wasn't when I read your earlier post.
[ jelv - the netgear notes are ambiguous - here's a link to 4.01.40 if you don't already have it:
http://kb.netgear.com/app/answers/detail/a_id/933/~/dg834v3-and-dg834gv3-firmware-version-4.01.40 ]
After installing 4.01.40 my download speed increased about a week or so later and is now around 14Mb/s; however to some extent the earlier instability has returned e.g. Saturday afternoon I had frequent disconnects and several mornings this week I've needed to disconnect/reconnect to obtain an internet connection. However it may be that the line is still going through a 'training period' following the firmware upgrade.
Best wishes
Jim
16-08-2012 10:27 AM
Sorry to hear there might still be an issue. FYI a firmware upgrade shouldn't have anything to do with a line retraining but I can see that after a solid 5 day connection that a fair number of disconnections have been logged over the past few days so unless things become stable of their own accord soon I'd look to raise a fault again: http://faults.plus.net
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image1345109183296.png" />
16-08-2012 1:19 PM
I'll keep an eye on things and log a fault as you suggest if the line doesn't settle down.
Jim
16-08-2012 1:55 PM
20-08-2012 10:52 AM
My connection has quickly become increasingly unstable and is again almost unusable. I've followed the link you gave to report a problem but can't log a fault unless I agree with the statement "I haven't tried with a different router and I understand that I could be charged if there's a fault with my equipment", and I'm reluctant to do this. I don't have another router and I'm not happy about buying a replacement when the one I have might be fine. Is there another way I can log a fault?
Jim
20-08-2012 4:58 PM
29-08-2012 10:04 AM
Thanks for your suggestions, though given that this can be an intermittent problem, I don't think asking a friend to give me access to their broadband connection would work. I'll give support a call and if they're unable to offer me a solution I'll explore other options.
Best wishes
Jim
