Frequent Disconnects and Speed Drop
Fixes: 334
Re: Frequent Disconnects and Speed Drop
Thanks for that @sweeep1963 . As you may see from that, your speed should be much higher, and you are actually below the hand back threshold - by a very tiny amount.
I would wait for one of the Help team to pick this up, but if they haven't by close of play (8PM) tomorrow, post back Monday.
sweeep1963
Yes I spoke to someone over the phone and it looks like they've done a reset as a speedtest now shows 39-40mbps, indicating a sync over 40 (I can't check to be exact as this modem doesn't show any stats), though still much lower than we've had in the past.
Fixes: 334
What modem/router do you have? If you can't get any stats off it/tem, I would replace them with something a little more useful.😉
sweeep1963
Just the openreach one, it is unlocked to check stats in the past but at the moment it's not setup
Fixes: 334
What router are you using?
sweeep1963
Edgerouter x
Fixes: 334
Don't know that one, but does it not have some reporting functions?
sweeep1963
I've got the modem stats working now, download sync rate is 42770 kbps, with attainable of 41408
Fixes: 334
Sounds about right then, but still low.
sweeep1963
Do these errors seem fine to you? Left column is downstream and right is up.
Fixes: 334
Over what period? Although that figure does look a bit high.
sweeep1963
The total on the right is since the last resync which was 1.5hrs ago. The left is per minute I believe.
Fixes: 334
Copied from a link found by Googling, as I am not an expert: An acceptable FEC rate is 100 per minute or 1500 within 15 minutes or 6000 per hour or less. Line interference from storm, electric motors, noisy ac line can cause increase in FECs.
sweeep1963
It seems FEC errors aren't really much to worry about anyway. I'm not sure what the Bitswaps signify. Also I can see that interleaving is on for downstream and off for upstream. This could explain the lower speed?
Fixes: 334
I was going to edit my post re: FEC's. In answer to your other two points - no, they have no bearing on your connection speed.
