Frequent Disconnects and Speed Drop
sweeep1963
For several months now, our internet is going down and requiring a reboot of the modem to start working again. This is happening anywhere from several times per day to several times per week. Also, the speed has slowly been dropping over the last 2-3 years (and even more recently) to the point where it is now barely above the minimum guaranteed.
I'd appreciate some help to check if the line is okay or any other suggestions.
37 REPLIES 37
Fixes: 334
Re: Frequent Disconnects and Speed Drop
@sweeep1963
A couple of self-help options:- (1) Check your phone line for noise - dial 17070 from your phone and select option 2 - after the confirmation of your phone number, the line should be totally silent except for the regular 'Quiet Line Test' announcement - ANY other noise report a phone fault via: https://www.plus.net/help/report-a-problem/phone/
If that passes as clear, report a Broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
If that declares 'No Fault Found', come back here, and we can try the longer way round.
sweeep1963
Hi, thanks for the suggestions. I had already used the troubleshooter and selected the line was clean as I just used the dial tone and could'nt be sure. I've just tried the quiet line test and there is some faint static though I cannot be sure as we no longer have a phone to connect directly into the socket.
Fixes: 334
How was your phone connected then - it has to be in the master socket to even work.
sweeep1963
I mean they are wireless phones
Fixes: 334
Ah -OK. So are mine, although I have a corded one for emergencies/testing. If there was any noise during the QLT, apart from the regular announcement, report a PHONE fault via the relevant link I gave you earlier, although it won't get picked up until tomorrow now.
Let us know what the result is.
Fixes: 1,639
I'm really sorry to see you're having connection issues. I've tested your line today and the tests aren't showing any problems. I can also see we've raised a fault with our suppliers who haven't found an issue either.
I've had a look at a graph showing your connection which I've attached below and things look stable from what I can see.
Are your devices connecting over WiFi or do you have a device plugged into your router which is dropping as well?
sweeep1963
Hi, all devices lose connection, both wired and wireless. The graph seems to show the moments which I am referring to, such as earlier today where the connection drops requiring me to manually unplug and replug the modem for the internet to work again.
sweeep1963
I have received this message after reporting the issue through the troubleshooter: Our suppliers have advised us that they have fixed the issue you reported to us. Would it be possible to have a DLM reset as the disconnections most likely caused the line to be banded?
Fixes: 334
@sweeep1963 What  results do you get from: https://speedtest.btwholesale.com/ - running the 'Additional Diagnostics'?
sweeep1963
The download speed is 36.7mbps with the IP Profile saying 38.6. Though the response from plusnet on the fault report showed this:
KBD Test Results
Circuit is in sync: true
Customer is online in RADIUS: true
Download speed: 40000
Upload speed: 10.9 Mbps
The 40000 is what made me think it may be banded, considering in the past we were getting over 50 and it has slowly come down.
Fixes: 334
I don't think that is banding. I'm not with PN, but my details show connection at 3995 - on a 40/10 profile - and I get around 37Mbps on a speed test. My modem/router reports the connection at 40/10, current throughput at 39.99, effective data rate 39.34.
sweeep1963
I checked https://www.broadbandchecker.btwholesale.com/ and observed speed yesterday was 39.99. Either way the decreasing speed is quite frustrating. I've just checked the broadband section of my account on the plusnet member centre and the minimum guaranteed speed is now 29.2, dropping from 35. A few months ago this "guarantee" was 40, and before that even higher...
Fixes: 334
@sweeep1963 What was your MGAL when you started this contract? Can you please post a screenshot of the wholesale checker, making sure you obscure your phone number?
sweeep1963
The MGAL has changed a lot since fibre first came to the area but over the last 5+ years or so its generally been 42-48. I've attached the screenshot of the wholesale checker.
