Frequent Connection Drops and long connection times
- Frequent Connection Drops and long connection time...
Re: Frequent Connection Drops and long connection times
30-11-2007 12:32 AM
over a maximum of 30 hops:
1 2494 ms 2 ms 2 ms 192.168.0.1
2 38 ms 34 ms 36 ms lo0-plusnet.ptn-ag1.plus.net [195.
3 37 ms 35 ms 34 ms ge0-0-0-303.ptn-gw01.plus.net [84.
4 36 ms 33 ms 33 ms ptn-cdns01.plus.net [212.159.6.9]
30-11-2007 12:47 AM
Sounds like you might have several problems, however returning to the line synch issue... If you find that when the modem loses synch and nothing you do makes it synch again, try phoning your house phone (from your moblie??) and answer the inbound call - see if you get immediate re-synch after that.
I've had a problem like this for weeks. PN Towers carried out lots of tests for me and could not locate a fault (such is the nature of intermittant faults, they are never there when you look). BT also undertook "extensive" tests and found "no fault with their equipment". 2 days ago a significant number of BT users in my area (myself included) lost all BT service. Now that they have fixed it the problem, my phone line terminates in the local pub!!!!!!
Morale of the story... Intemittant faults are never there when you look for them and following the rule book might not be helpful. PN have their hands tied behind their backs with the poor state of some of the BT network and when BT finally do fix the non-existant problem, you might need to go to your local to use you BB service!!!!
30-11-2007 1:41 AM
Quote from: Million Tracing route to ptn-cdns01.plus.net [212.159.6.9]
That was what I was expecting to see - how did you get the trace you posted here? (that caused us all some confusion!)
30-11-2007 8:23 AM
30-11-2007 8:28 AM
Quote from: Bob Could it have been done from work? It definitely didn't originate from a PN DSL connection.
Or over a VPN where he's using the remote end as the default gateway. You'd need to untick the box in the VPN setup (IIRC it's defaulted to use the gateway at the remote end with the Windows VPN client)to route non-VPN traffic through the local gateway.
30-11-2007 8:56 AM
I can certainly see a number of disconnections, with the last connection lasting for a couple of hours. You ideally need to run the Broadband Fault Checker. The reason why you keep on being asked to do so is because you haven't actually finished it yet, and it keeps on closing after 48 hours of inactivity.
You've tried the test socket, can you try changing filters and using a friends modem if possible?
30-11-2007 10:15 AM
The vpn i use is a cisco application that i log into, i dont use the manual windows vpn login.
So, ill try the new modem setup 2mo and get back to u all, and hopefully i will b able to finish the broadband fault checker also.
in the meantime ill monitor the line today and report back any drop-outs i have
Cheers
30-11-2007 10:21 AM
30-11-2007 10:28 AM
cheers
30-11-2007 10:39 AM
What the information you've provided has shown is that your VPN is not set up optimally. The routing should be arranged so that only the traffic destined for the office network goes over the VPN and all other traffic goes via your normal connection. I'm not familiar with the Cisco VPN so I can't point you in the right direction to sort that out.
30-11-2007 10:45 AM
If i do a trace within dos, i get the nornal 4 line trace as i pasted in late last night.
Hope that clears things up.
30-11-2007 9:34 PM
02-12-2007 2:36 PM
I had a BT voyager 220v to test, but it was locked to BT isp, so i tried to update with cracked firmware, half way thru that installation the firefox froze and now its a brick.
how can it be that 1 day its goos, 1 day its rubbish?
also any ideas how to unbrick the 220v modem would b helpfull, then i can test.
03-12-2007 9:31 AM
03-12-2007 12:49 PM
So i dunno if it is weather related, its rained like i have never seen on saturday day, and i didnt get any discons.
