Free domain offer expired?
oliverb
So the free domain offer had an expiry date? I never knew.
Missed my chance because I was still deciding what to use.
Re: Free domain offer expired?
Yep, it was only for 60 days.
But you can register a domain with the likes of www.123-reg.co.uk and www.1and1.co.uk for about £2.50 per year, so no great loss.
Chilly
minkey
Don't forget to go via www.quidco.com for chilly's links and you get cashback too!
Jeff
oliverb
Thats as maybe I'm still disappointed I never read of a time limit.
Plusnet Staff
Plusnet Staff
Fixes: 159
The time limit was 60 days from the date of launch, 21st June, this was announced at the time and looking at the previous forums there were some mentions of this in threads over there. Sorry you missed this.
 Chris Parr
 Plusnet Staff
nadger
I actually registered on the last day - where do I look for activation details.
Plusnet Staff
Plusnet Staff
Fixes: 159
If you chose to register for it but have not yet selected the domain then all you need to do is go through the normal route to register a domain. As long as you choose a .co.uk, .me.uk or .org.uk you won't be charged.
 Chris Parr
 Plusnet Staff
nadger
I did actually select a domain - nadger.me.uk. Is there a way of checking as doing a check using Easily it's still showing as available.
Cheers
Plusnet Staff
Plusnet Staff
Fixes: 159
That domain isn't showing on your account yet and it still shows as available to register.
So if you click this link and select that domain it should go through for you.
 Chris Parr
 Plusnet Staff
nadger
What bothered me, Chris, is that I screwed up making free registration.
Not a problem if I did as can live without the domain name.
Plusnet Staff
Plusnet Staff
Fixes: 159
If you want I'll go through and do it for you?
 Chris Parr
 Plusnet Staff
nadger
Quote from: Chris
Very kind of you to look after we oldies (in a literal sense) - if you could do that please  Wink
Plusnet Staff
Plusnet Staff
Fixes: 159
If you have a look at the domain names section of the portal you should see this domain now, it will tell you on there when it has completed the registration.
 Chris Parr
 Plusnet Staff
nadger
Thank you for the help, Chris  Smiley
nadger
That was really fast as already showing my details checking using Easily and have also had email from Nominet. Wink
