Forum rules
qwentyman
Forum rules
As a newcomer I'm struggling carefully to observe forum rules. The list of 'Don'ts' is helpful but sometimes I do not the 'how to'.
e.g how does one send a PM to a moderator?  Forgive me if this seems totally dumb.
pierre_pierre
Re: Forum rules
what do you want to do, just ask a question and it will probably be answered quickly Cool
Re: Forum rules
If you wish to PM someone just click on their username (on the left hand side of each post, alternatively there's a list of all members currently signed in at the bottom of each page) to be given  a variety of options. One of these is the option to send a PM.
Hope that helps,
Fixes: 18
Re: Forum rules
Just underneath the "avatar"  (or member picture) on left side, there are some small Icons..... hover over these to find the one that says "personal message"  click it, and you will be presented with the message box.... don`t forget to put in a "subject"  just like sending email..... When the person replies, you will get a message box presented to you to advise you that a message has been received..... go to the top of the page, and click on my messages.... you will then be able to read and respond to the message.....
Hope that helps even more ! ! ! Wink
pierre_pierre
Re: Forum rules
Orbrey reply is not quiet accurate, if you get the total forum page and then go down to the bottom is a list of who is on line
Note the colour codes
If it is only a short report, you could click the report to moderator at the bottom of the post you want to talk about.
Re: Forum rules
Would there be anything I could help you with?
B.
itsme
Re: Forum rules
and not all forums follow the some rules as shouting is allowed on the Polish Forum. Where can I find the rules for the Polish Forum?
Re: Forum rules
@itsme
The same link:rules apply to the Polish Forum as they do the main forums, the only exception to this is that it is moderated by the Polish PlusNet staff and not the Forum Moderators.
However, what mystifies me is the sudden interest in the Polish Forum from yourself?
itsme
Re: Forum rules
I want to see the forum rules applied equally. This is not happening with the Polish Forum as shouting has been allowed.
pierre_pierre
Re: Forum rules
Its probably like me, I click the Unread button, and up pops the Polish forum with the Thread topic all in Caps., there seems to have been a sudden rush in the last few days Wink
Fixes: 62
Re: Forum rules
and I see Roger has moderated it  Grin
Re: Forum rules
Well..
I needed to brush up on my Polish anyway  Cheesy
pierre_pierre
Re: Forum rules
He is pretty clever or did he get an interpretor?
Fixes: 62
Re: Forum rules
Fixes: 123
Re: Forum rules
Quote from: Oldjim
...and according to Systran he made a decent job of it..well done Smiley
Quote from: Oldjim
Have a look at this post then
Has everyone but me done a Polish course this weekend?
Edit: Except Jim who also did Swedish Sad
Customer and Forum Moderator.
