Force9 Broadband Your Way Pro
stepea001
I've got one of the old packages Force9 Broadband Your Way Pro - without paying anymore, is their any advantages in upgrading to one of the new packages.
Fixes: 59
Re: Force9 Broadband Your Way Pro
It depends on whether you are on a Market 1 or Market 2/3 exchange. Extra with the Pro add-on would give 60GB bandwidth per month (compared with your current 15GB). On a Market 1 exchange the latter would cost £3 pm more. On a Market 3 exchange it would cost £3.50 pm less - and I believe at the moment Market 2 pricing is the same as Market 3.
Exchange Checker to check your Market here.
Product Comparison Tool available here.
David
stepea001
cheers for that - just checked the exchange - market 2
puddy
Quote from: stepea001
If you change to a new package you will only get off peak unlimited from 12am to 8am but if you stay on your old package you get an unlimited service from 12am to 4pm every day
Plusnet dont tell you that
puddy
Fixes: 59
Peak period on all the BBYW products is 8AM to midnight, the same as for current ones.
David
matt_2k34
Actually they do This is a breakdown of each product
Only the *very* old, Pre-BBYW products had the different peak/offpeak timings. (e.g. Premier Option 1)
Regards
