Force9 Broadband Your Way Pro
- Force9 Broadband Your Way Pro
29-07-2011 7:24 PM
I've got one of the old packages Force9 Broadband Your Way Pro - without paying anymore, is their any advantages in upgrading to one of the new packages.
Message 1 of 6
(1,203 Views)
5 REPLIES 5
Re: Force9 Broadband Your Way Pro
29-07-2011 7:57 PM
It depends on whether you are on a Market 1 or Market 2/3 exchange. Extra with the Pro add-on would give 60GB bandwidth per month (compared with your current 15GB). On a Market 1 exchange the latter would cost £3 pm more. On a Market 3 exchange it would cost £3.50 pm less - and I believe at the moment Market 2 pricing is the same as Market 3.
Exchange Checker to check your Market here.
Product Comparison Tool available here.
David
Message 2 of 6
(547 Views)
29-07-2011 8:12 PM
cheers for that - just checked the exchange - market 2
Message 3 of 6
(547 Views)
30-07-2011 3:08 AM
Quote from: stepea001 I've got one of the old packages Force9 Broadband Your Way Pro - without paying anymore, is their any advantages in upgrading to one of the new packages.
If you change to a new package you will only get off peak unlimited from 12am to 8am but if you stay on your old package you get an unlimited service from 12am to 4pm every day
Plusnet dont tell you that
puddy
Message 4 of 6
(547 Views)
30-07-2011 2:21 PM
Peak period on all the BBYW products is 8AM to midnight, the same as for current ones.
David
Message 5 of 6
(547 Views)
31-07-2011 1:04 AM
Quote Plusnet dont tell you that
Actually they do This is a breakdown of each product
Only the *very* old, Pre-BBYW products had the different peak/offpeak timings. (e.g. Premier Option 1)
Regards
Message 6 of 6
(547 Views)
