Flashing broadband and no internet light
FforFRANKY
After everything working fine this morning, the internet light suddenly went down and the broadband light started flashing. I have tried to follow instructions here, I have no phone to check the phone line, but I have connected to the main socket and I don't use microfilters.
7 REPLIES 7
Legend
Fixes: 255
Re: Flashing broadband and no internet light
Welcome to the forums, @FforFRANKY . Just so this is on the correct board, can you confirm you are definitely on ADSL and not FTTC?
You say you don't use filters - is this because you have a filtered faceplate? A cheap corded phone is an indispensable piece of kit  for this kind of situation.
FforFRANKY
Hello! Thank you for responding!
Yes I have ADSL, and having just dug around and checked actually I do have a filter! It just only has one line from it as I don't use a phone, my apologies! Is my best option to go get a corded phone from somewhere? If I ring Plusnet can they check if there's a problem with the line?
Thank you again!
Legend
Fixes: 255
Thanks for confirming you are on ADSL. if you can borrow a corded handset, just to check the line is clear (dial 17070, option 2) - apart from the regular 'Quiet Line Test', there should be no noise at all -if there is, report a phone fault first.
If you can still access your router, sight of your 'Help Desk' tab, with personal details obscured would be a help to Community members, if they are to assist.
If you ring PN, they should be able to run tests to ascertain your issues.
Fixes: 1,600
Hi @FforFRANKY
I'm sorry to see you can't get online. I can see you've rang us earlier today and we've tested your line which hasn't found the cause for the problem so we'd need to arrange an engineer visit to investigate further.
Can you raise a fault to us at faults.plus.net? In the notes box at the end, please tell us when you'd be free for an engineer visit. The available timeslots are weekdays (and occasionally Saturday's) 8am while 1pm, or 1pm while 6pm. This means we'll be able to arrange an engineer straight away once we've picked the fault up.
Feel free to post back when you've raised the fault and we'll make sure that is picked up as soon as we can.
FforFRANKY
Hello!
Sorry yes I did ring and was asked to confirm an engineer, but the internet has returned at the moment. I am unable to have anyone free for an engineer slot this week anyway, so I'm going to see whether it goes off again, and if it does arrange one for next week. Thank you!
Fixes: 1,600
Ah no problem, fingers crossed your broadband doesn't go off again but let us know if you need any further help Smiley
FforFRANKY
Thank you! Really appreciate everyone's help!
