Flashing Internet Light
valart
Should my internet light be flashing on my router or should it be a solid green light I just wondered about this because is this the reason why my connection drops and reconnects from time to time.
Fixes: 20
Re: Flashing Internet Light
Which router?
Fixes: 24
Some router lights flash to indicate data flow.  Other routers have lights that do not flash because people worry about a flashing light.
Hi valart,
Your connection is disconnecting every 29 minutes;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13541840793705.png"/><div style="clear:both;"></div>
Are you using one of our supplied routers?
PeeGee
That's suggestive of "connect on demand" with a time-out and trigger (either router or connected PC based) at roughly equal intervals.
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
