Fixed Line
- Fixed Line
Fixed Line
12-01-2012 2:09 PM
Quote " I have tested your connection and I cannot find any issues which could be causing for the speed to drop. We can place an order to hard fix your line at 2 Mb/s as the profile for your line would not change," Advice Please
Re: Fixed Line
12-01-2012 2:23 PM
Re: Fixed Line
12-01-2012 3:21 PM
Re: Fixed Line
13-01-2012 10:03 AM
Re: Fixed Line
13-01-2012 10:26 AM
General Information
DSLAM: Country: {0x0F} Vendor: {ALCB} Specific: {0x00}
DSL Line (Wire Pair): Line 1 (inner pair)
Downstream Rate Cap: 8128 kbps
Downstream Atten. at 300kHz: 68.4 dB
Uncancelled Echo: -13.1 dB Ok
VCXO Frequency Offset: 24.4 ppm Ok
Final Rx Gain: 34.5 dB Ok
Impulse Noise Comp. Tones: 0 Ok
Excessive Impulse Noise: 0 Ok
Impulse noise protection: 0.69
Delay of latency path: 4.00 ms
Training History
Downstream Upstream
Time Line Rate Max1 Max2 Max3 Mgn1 Mgn2 Attn Pwr CRCs FECs INP DLY Rate Max Mgn Attn Pwr CRCs FECs Mode Vendor State Exit Code Echo VCXO Rx Gain INC Tones
2012/01/13 10:16:00 GMT 1 2016 2020 1592 1592 6.0 6.0 68.0 16.9 0 289 0.69 4.00 448 628 12.0 31.5 11.9 0 0 G.DMT Annex A Alcatel 229/103 N/A -13.1 24.4 34.5 0
Notes:
Time Time of last update
Max1 Max. rate at start of connection
Max2 Current or final estimated max. rate
Max3 Current or final estimated max. rate without INC
Mgn1 Noise margin at start of connection
Mgn2 Current or final noise margin
State Internal training state
Exit Code Cause of retrain
INP Impulse noise protection
DLY Delay of latency path
Bitloading
Before Reboot
Troubleshooting – DSL Diagnostics
General Information
Downstream Atten. at 300kHz: 68.8 dB
Uncancelled Echo: -16.0 dB Ok
VCXO Frequency Offset: 24.9 ppm Ok
Impulse Noise Comp. Tones: 2 Suspicious - impulse noise detected
Impulse noise protection: 0.67
Training History
Downstream Upstream
2012/01/12 17:20:58 GMT 1 1792 1816 912 912 6.3 1.0 68.5 16.0 3975 51097 0.52 4.00 448 616 11.0 31.5 11.9 1706 2312 G.DMT Annex A Alcatel 230/105 ERR_SIG_INTERRUPT -12.9 24.6 34.5 0
2012/01/12 19:21:12 GMT 1 1120 1128 1316 1316 6.1 -2.0 68.5 16.2 3673 18284 0.62 4.00 448 620 11.0 31.5 11.9 949 1017 G.DMT Annex A Alcatel 230/105 ERR_LOF_LIMIT -14.0 24.3 34.5 0
2012/01/13 10:10:48 GMT 1 320 324 732 732 6.2 13.0 68.4 12.6 7 2388 0.67 4.00 448 624 11.0 31.5 11.9 28 174 G.DMT Annex A Alcatel 229/103 N/A -16.0 24.9 34.5 2
Notes:
No virus found in this message.
Re: Fixed Line
13-01-2012 1:25 PM
A fixed 2M connection is basically one of the first ADSL products that was released - when broadband was available in 512k, 1Mb and 2Mb speeds. Basically your downstream would be fixed at 2000Kb/s and your upstream at 256kb/s and those figures wouldn't change.
If you don't often get sync above 2000 I'd recommend going for the fixed product as you wouldn't get the slowdowns and fluctuations in speed that you've been noticing.
Hope that helps explain.
Re: Fixed Line
13-01-2012 2:02 PM
Re: Fixed Line
13-01-2012 2:32 PM
Re: Fixed Line
13-01-2012 2:45 PM
Re: Fixed Line
13-01-2012 3:18 PM
Re: Fixed Line
13-01-2012 3:26 PM
Quote Impulse Noise Comp. Tones: 2 Suspicious - impulse noise detected
That's not good. Usually indicates some external noise affecting the ADSL.
See here http://www.dslreports.com/faq/12336
From those figures it looks like the router (I assume its a 2700hgv) is struggling to maintain a synch at much above 1M during the late evening. You seem to be getting some large variations in SNR during the 24hours and without finding the underlying cause for that I'm not convinced that you will maintain a synch during the evening on a fixed 2M product.
Re: Fixed Line
13-01-2012 3:39 PM
Re: Fixed Line
15-01-2012 5:52 PM
Re: Fixed Line
15-01-2012 8:49 PM
Re: Fixed Line
16-01-2012 12:11 AM
