Fixed IP on Value package?
- Fixed IP on Value package?
17-09-2012 2:44 PM
Re: Fixed IP on Value package?
17-09-2012 2:52 PM
The people who have it retained it when they moved from an earlier package which included it
17-09-2012 7:47 PM
dick:quote
17-09-2012 7:59 PM
http://www.plus.net/support/broadband/products/res_broadband_faq.shtml#ipAddress
Do I get a Dynamic IP or Static IP?
All our accounts connect with a Dynamic IP address as standard.
Plusnet Extra & Pro customers can request a Static IP if needed..
Looks like you would have to move to the exta package to get this.
Regards
Mike
13-11-2013 4:52 PM
13-11-2013 6:40 PM
However, searching the internet for solutions, there are lots of mentions of setting the computer (running Echolink) on your LAN to have a static local IP address, in order to make port forwarding on your router easier.
I could be wrong, but I think you might be talking about two different things.
Regardless of the above, once you are on 'Unlimited' (tomorrow), then you can add a static IPv4 internet address to your account for a one-off payment of £5. Once activated you will need to reboot your router for the static IP address to be applied to your connection.
13-11-2013 7:00 PM
This has happened before but at some time it will stop working. Using www.yougetsignal.com/tools/open-ports/ tool shows the ports closed so I don't know how it's working. Never mind, I shall leave it as it is and keep using it.
I think you may be right ref local LAN having a static IP address, I don't know how that works (as you can tell) so I will leave THAT well alone as well......
Thanks again.
BTW when I checked internet connectivity it shows connectivity to DNS server 1 & 2 (212.159.6.10/9) as not connected. does that matter?
13-11-2013 7:12 PM
Quote from: bertb BTW when I checked internet connectivity it shows connectivity to DNS server 1 & 2 (212.159.6.10/9) as not connected. does that matter?
What is telling you that the DNS servers are not connected ?
Are you connected to your router via wireless ?
13-11-2013 7:33 PM
Under Internet it has:
Tick connectivity to Gateway (195.166.128.186)
X " " to DNS Server 1 (212.159.6.10)
X " " to DNS Server 2 (212.159.6.9)
13-11-2013 7:43 PM
13-11-2013 8:08 PM
