Fixed DNS works sort of
- Fixed DNS works sort of
15-04-2012 10:34 PM
Had the connection drop. Finally got through - variously 25 and 35 minutes waiting times and was talked through to a fixed DNS of 212.159.13.49 .. etc
Okay that works for my PC, but I can't set the DNS on my Phones nor my Blu-ray nor freesat all of which are web connected - or used to be. Then there is my works laptop which I cannot change the DNS back and forth which was the point of going to plusnet from orange so I could have a fixed IP. That is becoming less and less of a need as my need now is just simply to have a reliable internet connection.
DSN remains fine, just no DNS!
10 years with Freeserve / Wanadoo / Orange with virtually no downtime, now swicthed to plusnet, basically for a static IP and I have spent more time trying to get a connection this last week than in the whole previous ten years! As to hearing a Yorkshire accent!
I tried to revert back to Orange, but they said that as I had handed over my MAC code that was it!
Message 1 of 2
(741 Views)
1 REPLY 1
Re: Fixed DNS works sort of
16-04-2012 12:47 AM
If you put the fixed DNS settings in to the router that should take care of the other devices and leave them to get the DNS settings from the router.
Message 2 of 2
(290 Views)
