First thoughts on the "new" Technicolor TG589vn v3
bill888
Champion
Fixes: 38
Re: First thoughts on the "new" Technicolor TG589vn v3
Quote from: Hairy
Had to power it down this afternoon to move it to its permanent hole home, when I powered it backup it wouldn't connect to PN, the fibre connected but no pppoe.
Even using the Connect button did nowt.
Just a thought, but could this be related to the 8 minute PPPoE timeout issue reported elsewhere on the forum?
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
HairyMcbiker
All Star
Fixes: 21
Possibly, it wasn't 8 min though more like 3-5.
bill888
Champion
Fixes: 38
Did you log into the router and Disconnect the PPP session before powering off and moving it?
HairyMcbiker
All Star
Fixes: 21
Nope I just switched it off.
HairyMcbiker
All Star
Fixes: 21
I also seem to have to log in multiple times on the web page - the first log in is NEVER accepted. Then subsequent ones are without changing u/p details.
AndyH
I used to have that problem with a Zyxel router many years ago.
Is the TV light for IPTV?
HNKS
So you dont need the BT openworld modem with this for Fibre broadband?
AndyH
I would be very surprised if you didn't need the fibre modem still with this router.
I don't think any ISP is offering a fibre modem + router in one and the alternatives are very expensive.
ejs
Aspiring Hero
Fixes: 25
Quote from: Hairy
It is a combined Modem/Router for adsl & Fibre - you don't need the BT modem any more and get stats
Here are mine :-
DSL Connection
Link Information
Uptime: 0 days, 5:56:01
DSL Type: ITU-T G.993.2
Bandwidth (Up/Down) [kbps/kbps]: 20.000 / 79.987
NorthEasterner
Quote from: AndyH
BT are later in the year with their new homehub 5
Would definitely be investing in the hub 5  Smiley Smiley
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
Pyrii
Lack of gigabit is a no-go for me. It seems silly to not bother supporting it given that alot of people will start having gigabit networks now. The switches are inexpensive and it can use existing RJ45 Cabling.
NorthEasterner
@Pyrii Gigabit networks are up to 1GB in speed.  Using the gig port won't increase on speed for internet.
But may increase speeds on transferring files between computers (depends on PC)
HairyMcbiker
All Star
Fixes: 21
I have a gigabit switch which feeds all my pc's (only 3 devices on gigabit) and other bits, but if the fibre was ever to go to over 100Mb then it would be a limiting factor.
Quote from: HNKS
Nope I have mine sitting on top of my scanner at the moment with the psu lying next to it.
WiFi:
got around to testing the video streaming last night, seemed fine, but I only tested for a few min not for a whole movie (NB @ 720p via the NowTV box)
So far MUCH better than the previous router from PN. The web pages need tidied up and some additions already mentioned, like access to the dns server settings, incoming dns servers, proper access to the dhcp/static ip bits & allow user to SET static IP not just the allocated one.
HairyMcbiker
All Star
Fixes: 21
Just found a bug in the gui
On the dsl/details page
Uptime: 0 days, 18:21:53
Data Transferred (Sent/Received)[B/B]: 0 / 0:
Now I KNOW I have had my radio streaming all day/night, and downloaded a bit last night so there should be something in there  Wink
HairyMcbiker
All Star
Fixes: 21
Fixed my bb ping graphs, forgot to enable bb pings  Embarrassed
Same setup as the 582, firewall/Allow PING on your WAN interface <- down the bottom of the page.
