First ten days
manfromthezoo
First ten days
OK, so....I have a question relating to the first ten days use (which started last night), under which my line conditions are assessed. Taken from PN's own comments on the matter:
We'd like you to help us with the tests too. So that we can get accurate results it's important that you connect to the Internet as many times as you can during the first 10 days. When you do this it's a good idea to switch the power to your modem or router off then on again (once or twice a day is fine). This will force your equipment to reconnect. After 10 days, your speeds will start to settle down and give you the best service your line can support.
I'm going to power-cycle my router tonight, then. Does this mean that given a stable line has been running for nearly 24 hours previously, I should get better performance? Looking at the control panel, it seems I am currently getting 2.1MB, from a 3.5 estimate. Alright, I know it's just that - an estimate. Of course, I could have misread this, and it is actually referring to getting as many resyncs as possible in the first ten days?
Any tips for exploiting this period to establish the best possible sync and transfer speeds?
Thanks.
27 REPLIES 27
Fixes: 1,483
Re: First ten days
Don't restart your router at night! It's better to do it during daylight hours.
manfromthezoo
Re: First ten days
Gotcha. Thanks. What's the difference, incidentally? Is that due to peak evening demand forcing slower sync for capacity issues....thusly pushing down your IP Profile?
Fixes: 1,483
Re: First ten days
Less interference during the day.
zubel
Re: First ten days
It's good behaviour to restart a router in the morning rather than the afternoon, primarily because of interference.
Interference can occur from many sources, such as household electrical items, which are often turned off first thing in the morning (TV's, microwaves etc).
Also, the DSLAM at the exchange will have several 'pairs' of connections plugged into it.  These connections are all in very close proximity to each other, and there is the potential for crosstalk interference from those pairs (although the design of the interconnects should minimise it).
Also, RF propagation is much greater during darkness, so the electrical item a couple of doors down that is kicking out a huge RF interference pattern may not 'reach' you during daylight, but could during the nighttime.
Basic conventional wisdom is to restart routers when no-one in close proximity to your router, or any part of your telephone line, is doing anything major!  (read:  mornings, up till about midday :))
B.
manfromthezoo
Re: First ten days
Appreciated, chaps.
I'm also thinking of getting me dad to fit an ADSL Nation XTE-2005 Master Faceplate (he's an old BT engineer). He's done a few before, and the difference has been staggering.
Is this advisable during the first ten day period though?
Again, thanks.
manfromthezoo
Re: First ten days
Just thought I'd bump this, people.
I'll be honest - it's impatience. I have a filtered faceplate right here, and I'm itching to know whether fitting it is safe during the ten day stabilisation period. I raised a ticket too, but if I can get an answer I'll close it to take the burden off the (very busy) support staff.
Strat
Fixes: 565
Re: First ten days
I don't see the people on line just now that could give a definitive answer to that.
Personally I can't see a problem but I'm not the expert.
Hang fire if you can.
manfromthezoo
Re: First ten days
Yeah I'm gonna sit on it a bit. I reckon it might be a good shout though - connection to the test socket syncs at nearly a meg more.
Strat
Fixes: 565
Re: First ten days
Which points to internal issues like poor wiring, bell wire, Sky box etc.
mal0z
Re: First ten days
Quote from: Barry
pedant mode
For the frequencies used by ADSl i.e up to a 2MHz or so yes - but actually it's because of reflections of the inosphere ( why you get longer range reception on medium wave.
At higher frequencies - lets say above 40MHZ  whether its daylight or make makes no difference.
/pedant
manfromthezoo
Re: First ten days
Yep. We just moved into this flat and I suspected extension wiring circuit might cause some botheration.
mal0z
Re: First ten days
Where's your master socket - hopefully it's inside your flat ?
manfromthezoo
Re: First ten days
It is, yes. With (sort of) easy access.
I have an ADSL Nation XTE2005 on order.
mal0z
Re: First ten days
That's good then, a friend of mine lives in one of those flats converted in a large house - and the telephone wiring left much to be desired - i don't think a BT technician has ever stepped over the threshold.
