First post - Question on BB sped management
- First post - Question on BB sped management
- « Previous
- Next »
Re: First post - Question on BB sped management
15-10-2008 2:00 PM
Quote from: pierre_pierre a subsidiary question BT speed tester went belly up a couple of weeks ago, some people have got it back, I havnt. I have two system
Linux on a Asus Eeepc - cant change it, java fault
XP on two laptops. Have cleared cache reinstalled java, cleared old copies of java still not working. Now what?
I suspect that BT made a change in the way uses Java. I don't know about Linux but I've found that with Windows I can get round it by logging in as Administrator (not my normal user which is given full admin rights). Actually I'm using Vista Home Premium but I believe the same may apply with XP.
Message 31 of 33
(160 Views)
15-10-2008 7:22 PM
dont know who changed what, wasnt working this morning, I made no changes, it is now
Message 32 of 33
(160 Views)
05-11-2008 6:47 PM
Todays stats
SNR Margin 14.7 19.0 dB
Line Attenuation 56.7 31.5 dB
Errored Seconds 27 2
Loss of Signal 0 0
Loss of Frame 0 0
CRC Errors 29 3
Data Rate 1664 448 kbps
Latency FAST FAST
BB speed test at 1.4
Had to reboot the modem when I got home, checked the stats
Loss of Signal 0 0
Loss of Frame 0 0
CRC Errors 29 3
Latency FAST FAST
Message 33 of 33
(160 Views)
- « Previous
- Next »
