First Connection
sully666
First Connection
Connected to Plusnet today and here are my line stats.  Do they look ok?
Link Information
Uptime: 0 days, 0:11:11
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 448 / 17.225
Data Transferred (Sent/Received) [MB/MB]: 3,19 / 28,66
Output Power (Up/Down) [dBm]: 11,8 / 20,9
Line Attenuation (Up/Down) [dB]: 5,5 / 11,0
SN Margin (Up/Down) [dB]: 23,8 / 5,9
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 1 / 1
HEC Errors (Up/Down): 0 / 1
15 REPLIES 15
adamwalker
Fixes: 221
Re: First Connection
That looks fine to me, the downstream speed is a little below your estimate but the connection is subject to a 10 day line training period so you should see that improve a little.
Adam
 Adam Walker
sully666
A Little disappointed with speedtest results so far. Struggling to get over 14.8Mbps, when I was always getting over 16Mbps with my old ISP. Upload is even worse, speedtest was always over 1Mbps, but is now struggling to get over 0.35Mbps.
Is this likely to improve after the training period or do I need to get a different modem/router?
Was told the TG587N v2 I had was better then the TG582n, but wouldn't know what to get at a reasonable price.
grahamt
I believe that the upload speed for new ADSL2+ connections is capped at 448 by default - but you can ask for it to be uncapped (at the risk of a slightly slower download speed).
Graham
Pettitto
Fixes: 5
We can certainly get the upload speeds uncapped for you?
Once the initial training period has completed, I'd be more than happy to take a look at things for you?
sully666
Not sure at the moment that I want to sacrifice download speed for upload.  Probably just need to get use to it  Undecided
Would have preferred to use my TG587n v2 as it seemed to have better wireless signal but all the options to set it up mentioned my old ISP.
Pettitto
Fixes: 5
It's unlikely to have much of an effect on your downstream speeds to be honest.
It's completely up to you of course, it can be added (takes 24 hours) and removed(further 24 hours) if you just wanted to try it Smiley
sully666
May be worth a try then.  I know I am waiting on static IP as well.  A couple of games I play online are easier to set if the IP is static.
Pettitto
Fixes: 5
Your Static IP is active now.
Oldjim
Resting Legend
Fixes: 63
and what is the rDNS set at
sully666
Quote from: Chris
I assume the uncapping will happen after the training period?
Oldjim
Resting Legend
Fixes: 63
it can be done immediately
orbrey
We'll uncap it as soon as the phone order has completed, unfortunately we can't place any further orders while that's ongoing.
Pettitto
Fixes: 5
I've placed an order your upload speeds to be uncapped.
I should have posted earlier as Matt had seen an order there and wasn't aware it was an order I'd already placed for you!
Should all be sorted for you tomorrow morning Smiley
sully666
Any news at all on the phone situation?
